Announcements
Components left floating after inserting a gallery design into current design
Jacques_Bayman
Jacques_Bayman
https://autode.sk/3be4gYqHi
I have inserted a design from the gallery into a current design, but then some components start to float behind the PCB. Opening the file by itself and on the webview looks fine. Here is the design I inserted. HC-SR04 sensor
Also see screencast.
HughesTooling
Think the problem is there's a capture position pending in the source file. Try capturing the position then save. By the way you should avoid capture positions in designs as they hit performance, you should be able to build designs using only joints.
Mark
Mark Hughes
Owner, Hughes Tooling
Jacques_Bayman
Hi. Great! That solved it for me! The part is not my design, I simply copied it to save me from messing with my own measurements. I have send the owner a note about it. I never knew about the performance issue. I thought joints would be worse than just a position?
Regards
