Announcements
Components inserted from McMaster Carr no longer are added to active assembly
max.armstrong9BJVM
Observer
max.armstrong9BJVM
Observer
Observer
In the newest fusion update, parts inserted from McMaster carr no longer end up being added to the active sub-assembly. Parts instead have to be added after the fact, which often does not work without annoying workarounds.
For example, see the photo below. "Overhead gantry..." was active when the McMaster part shown was inserted using the usual method of: INSERT --> Insert McMaster Carr Component --> download as .STEP file.
RajkumarIlanchelian
@max.armstrong9BJVM We are aware of this issue and actively looking to address it.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
RajkumarIlanchelian
@max.armstrong9BJVM Thank you for your patience. We have now addressed this in an update 2.0.18477.
Autodesk Fusion
Join Fusion Insider
