Component Radio Button no displayed
SGoldthwaite
SGoldthwaite
The radio button in the browser tree that you use to activate a component doesn't always show up. I can right click and activate, but sometimes the radio button is there, other times it's not. It seems kind of random.
See screencast:  http://autode.sk/2BsJLXw
I'm on a Mac ver 10.11.6
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @SGoldthwaite
Thank you for reporting this issue.
Does it happen a specific model or all of models? If it happens a specific model, could you share your design? Here is how to share it
Unfortunately, I was unable to reproduce it and you already mentioned it sometimes happens so I asked it to development team (FUS-37455)
If I receive any response, I will get back to you.
I look forward to your reply
Many thanks,
Ahreum.
SGoldthwaite
matej.biro
It happens to me too , not offen but sometime when i work on desing for longer time, restarting fusion mostly help.
Similar issue happen with light bulb too, when i want to show/hide components and move with cursor over lighbulb, name of that component slide right and i click on triangle icon instead. Then when i move right on lightbulb name go left to its basic position and i am on name of component again. I have to be rly fast with clicking to avoid that behavior. Its pretty anoying sometimes when i have to do it with more components. It apear randomly.
Using iMac OS
jeff_strater
@SGoldthwaite,
When this happens, it seems to be with component names that are long enough so that they bump up against the right side of the browser.  If you make the browser wider, does that prevent the problem?  I found I can reproduce this by making the browser narrower, but not narrow enough to actually cut off the name.  But, if I play around with it a bit, make the browser wider, iconify and bring back Fusion, I can get it to fix itself.
The UI team is looking at this now.  Thanks for bringing it to our attention.
Jeff
Jeff Strater
Engineering Director
