Fusion Support
Component gets dark as I zoom in.
1 REPLY 1
sed.elmi
92 Views, 1 Reply
Its a big file but eveytime i zoom into my chosen body, the part goes dark. Making it really hard to select faces.
1 REPLY 1
jhackney1972
in reply to: sed.elmi
This is probably a graphics issue.  You can check to make sure Fusion 360 is using your dedicated graphic card using the Graphics Diagnostic panel.  Also make sure you have the lasted graphics card drivers installed. Last, try a different Graphics Driver from the Preferences panel.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
