Announcements
Component Color Cycling produces wireframe
troy.salmon0
Message 1 of 9
troy.salmon0
For starters, I am very new to Fusion 360 so I may very well be missing something simple.  I updated to the new version this morning (2.0.5508 on Windows 10 pro) and after doing so, one of my projects now has a problem.  When I turn on Component Color Cycle Toggling, it turns one of my components into a wireframe or maybe a clear color that results in a wireframe like view. Two of the three components in this project display fine but the third doesn't.
Is there a way around this or will I just have to turn off that feature when working on this component?
(This is a re-post because my first one was flagged as spam for some reason)
Replies (8)
Message 2 of 9
keqingsong
I noticed that your "Base 1" component doesn't have the same pronounced edges as your "Hub 1". There seem to be some graphical weirdness happening. Can you try 2 things?
1. Go to Effects under Display Settings and turn everything off except for AA.Screen Shot 2019-03-12 at 11.23.07 AM.png
2. Restart your machine
Let me know if this fixes it.
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Message 3 of 9
troy.salmon0
That didn't fix it.  I unchecked everything but anti-aliasing with the exception of Ground Shadow because it is grayed out and I can't select it.
Message 4 of 9
ryan.bales
Autodesk Support
Autodesk Support
I"m not sure why it got flagged as i had already replied but oh well. Both Keqing and i likely need to see your file to see if its model specific.
Ryan Bales
Fusion 360 Product Support
Message 5 of 9
troy.salmon0
Ok, here's a link to the model.
https://a360.co/2EQyq2w
Given my total lack of experience with Fusion, I don't doubt that it may be something I did along the way that was outside the conventional methods and therefore caused this anomaly.
Message 6 of 9
ryan.bales
Autodesk Support
Autodesk Support
It's the opacity of the bodies and components. First set the opacity of the component to 100% then each body. It should remain visible and clear when toggling component color cycle on or off
Ryan Bales
Message 7 of 9
troy.salmon0
Problem solved.  Thank you very much.
Message 8 of 9
ryan.bales
Autodesk Support
Autodesk Support
Of course! Glad to help!
Ryan Bales
Message 9 of 9
mmcnaught831
Hi - so what was the solution? I've been having this issue for a long time with Fusion, and the only thing that helps (temporarily) is to restart fusion. The problem usually reappears within a single modeling session. Running latest fusion version.
