Evaluating two similar components, not two different versions in Fusion, to verify that an externally supplied CAD model matches my model, is critical for many applications.
When using the "Compare" command I get an error message:
"There was a problem combining geometry together.
If attempting a Join/Cut/Intersect, try to ensure that the bodies have a clear overlap (problems can occur where faces and edges are nearly coincident)."
Ideally there should be no or minor differences the components but then Fusion does not work!
Ideally, there ought to be a "Difference" command.
There is a detailed thread posted by me: "Compare two independent bodies , not two versions of the same part?"
By the way, I am surprised that there is not an ID# for forum messages to make it easy to reference and search.
Bertho
