I have a small created sphere body located on an elliptical path. I pattern it using the Pattern on Path command without issue. After patterning I need to Combine all the patterned bodies with the base body. During this Combine, two of the patterned bodies disappear. I would appreciate it if someone could tell me how to avoid this issue or register it as a flaw in the application. My model used in the Screencast is attached. It is at the point where the Combine should occur.
John Hackney, Retired
