combine function dont work
davidsadibolSQ7K4
Message 1 of 9
davidsadibolSQ7K4
my combine function doesnt work on this components any suggestions why ?
when i select combine i can click on 1 component but i cant select any tool bodies
Replies (8)
Message 2 of 9
TheCADWhisperer
@davidsadibolSQ7K4
Message 3 of 9
HughesTooling
It looks like all you have are instances of one component. If you create another component for one end of your crankshaft and select as your target body you will then be able to select the component copies as tools.
Here's a simple example. The first 3 components are instances and if I select component2 I can join the bodies from all the copies of component1
Mark Hughes
Owner, Hughes Tooling
Message 4 of 9
davidsadibolSQ7K4
here it is
Message 5 of 9
davidsadibolSQ7K4
yea my english is not best but i did what i think u typed and it doesnt work but i may be wrong in translation
Message 6 of 9
HughesTooling
If you select the hub first then select each section of the crank it will work. Note after selecting the first section the others become invisible but do highlight when you mouse over.
Mark Hughes
Message 7 of 9
HughesTooling
@davidsadibolSQ7K4 File Attached for reference.
Mark
Mark Hughes
Message 8 of 9
davidsadibolSQ7K4
thanks so much
i couldt figure this for like 2days
Message 9 of 9
HughesTooling
@davidsadibolSQ7K4 wrote:
thanks so much
Not a workflow I've used but when you think about it you can't combine bodies that are all copies of one component back into that component.
You might want to turn on component colours (Shift+N) so it's a bit more obvious what component's you're working with. A lot easier to see like this.
Mark Hughes
