Combine bodies failures
rickhenson
rickhenson
Hi, I am experiencing difficulty with a particular "Combine Bodies". There appears to be no errors in the underlying sketches or the bodies themselves. No matter what I try I cannot join, cut or intersect. I have attached the file and I'm trying to combine the body "Moose V11R"  with any of the bodies in the "Frames R" bodies group. I have tried everything I can think of to counter the error messages that appear but no love.
jhackney1972
Here you go, model is attached.
John Hackney, Retired
rickhenson
HI John,
couldn't see any attached models. What did you do to fix this?
Rick
jhackney1972
Sorry, the model did not attach. The bodies were not touching each other.
rickhenson
Thanks John,
how were you able to determine the bodies weren't touching. I ran a section analysis and it looked good.
jhackney1972
The bodies would not combine so I suspected they were not touching, at least all over the bodies surface.  To make the contact necessary, simply scale one of the bodies by a minimal amount.  I used a scale ratio of 1.001 which is undetectable.  If this answers your question, please remember to select the Accept Solution icon on my post.  If you have further questions, please ask.
rickhenson
AWESOME!!! Thanks so much. Great fix, I never would have thought of that. Done this before have you. 🙂
