Announcements
Color Cycling Palette Has Changed
gdw971
gdw971
The palette for color cycling has changed. It used to show bright colors. Now all of the colors are darker and dull. How can I restore the original color cycling palette?  Note, this duller palette is a fusion setting now since the dull palette occurs even for new projects.  I may have inadvertently done this when I was exploring properties and appearance.
Thank you.  gw
Accepted solutions (3)
jeff_strater
I'm pretty certain that nothing has changed on the Fusion side in this area for a very long time.  Can you show a screenshot of what you are seeing, and share a model you are working with?
"I may have inadvertently done this when I was exploring properties and appearance. "  Can you explain more?  I don't think that editing appearances can affect color cycling, at least as far as I know
Jeff Strater
Engineering Director
jeff_strater
Is it possible that you have started using a different environment (Dark Sky, Tranquility Blue, etc), because the cycling colors are different in each environment.
Screen Shot 2021-05-21 at 1.40.42 PM.pngScreen Shot 2021-05-21 at 1.40.27 PM.pngScreen Shot 2021-05-21 at 1.40.08 PM.png
Jeff Strater
gdw971
Ah.  Thank you so much.  I think I had changed the environment from photo booth to infinity pool.  🙂
