Fusion Support
Collinear constraint being applied without error in sketch environment but not actually doing anything?
1 REPLY 1
FrodoLoggins
77 Views, 1 Reply
Ok so in the below video you'll see me offset some projected geometry, remove the offset dimension, and then apply a collinear constraint.
The constraint is applied successfully (no error/warning thrown, constraint icons displayed next to geometry) but the line I want collinear with the dotted projected construction line doesn't move and isn't collinear:
https://youtu.be/npIz10R_h1w
The geometry does not appear to be constrained as I'm able to move the "constrained" offset geometry willy nilly and upon doing so I get the below error:
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
1 REPLY 1
@FrodoLoggins wrote:
... remove the offset dimension, and then...
Delete the Offset Constraint.
See Attached.
