Colinear, Perpendicular, Parallel Constraints 'Flipping' 180 Degrees to Alternate (Undesirable) Solution
Sometimes when I specify colinear, perpendicular, or parallel constraints, sketch geometry constrained in this way will 'flip' 180 degrees to the alternate colinear, perpendicular, or parallel solution from what is desired for the part geometry. It seems like a bug because it should be pretty clear from inference which orientation is the desired mathematical solution. Is there some setting to deal with this, or is there a reliable workaround to make sure geometry can find a stable, singular solution without using some complex scaffolding and sketch dimensions (constraints only)? I don't understand why this behavior would be desirable, Autodesk, so please fix! I've never had these issues with SolidWorks or Unigraphics. I understand those are more 'premium' CAD packages, but having stable sketch geometry is pretty basic functionality.
