Announcements
Coincident error after import of SVG
Hi
I have imported an SVG. as you can see, i need to join the end points but i get an error. can you help please?
TheCADWhisperer
Thanks for getting back to me. After playing around for a while i noticed that i had the option to "Delete Coincident". may me wonder if removing it would fix the error, it did.
Was this the correct fix?
I have attached the f3d file and an image showing where the issue is.
Thank you
g-andresen
1. isolate the gap with the divide and conquer method
2. replace the broken arcs with new arcs
screencast
günther
