Message 1 of 9
This may be in the wrong area but I have a number of issue with the new coil command.
I don't know when or why the command was changed but it is very difficult to use now and also keeps causing Fusion to freeze. I have also had issues with the coil command feature not showing in the timeline so the only way to delete it is to exit and recover a previous version of the design.
This part is not a bug report but:
I need to create a simple lid which will set down over tabs and rotate 90 degrees to lock. This was simple using coil before but I cannot get it to work for this now.
