@HughesTooling wrote:
Not clear if you have this working or not. If not try this, on your mac in data panel Assets CAMTools folder rename the library that's not syncing, make sure your windows Fusion is closed down first. The library should then be renamed if you go to the CAM workspace and run the tool library manager, if not wait a few minutes as it can take a while to sync. You used to be able to set the sync time for cloud libraries but not now.
If the above works try starting the windows PC and see if it picks up the change.
Mark
I renamed the library, but I still saw syncing problems. Here's what I did:
MAC: Renamed tool library via data panel
MAC: Added tool 410 and closed Fusion
Win 10: Opened Fusion and tool library - Fusion showed original library name, renamed library wasn't synced
Win 10: Closed and re-opened Fusion, waited a couple minutes. Now the renamed library was there along with tool 410. Looks like it just needed a few minutes to sync
Win 10: Added new tool #411
Mac: Opened tool library, the new tool(# 411) I added in Win 10 was there.
Mac: Deleted tool 401. Closed Fusion
Win 10: Opened Fusion, tool 401 was still there, it was not deleted. Waited a few minutes and checked again, tool 401 was still not deleted
Mac: Opened tool library, tool 401 was not there. Closed Fusion, didn't make any changes
Win 10: Opened Fusion, opened tool library, tool 401 was still there, not deleted. Cleared cache and restarted Fusion, opened tool library, tool 401 was not there. So clearing cache in Win 10 was necessary for the Tool library to sync properly
