I use Fusion at home and at work and I been having issues with a warning, "Unable to validate a security certificate", also fusion stopped opening at all, I checked some of the forum comments and I ended doing a do a clean uninstall and was able to access again, but the warning "Unable to validate a security certificate" keeps showing and NOW after re-installing Fusion at work I went home to find that somehow the session still alive and when i try to access from home fusion tells me that a session is opened, so i have to suspend the other pc, I don't have a Proxy server at home or at work, so i guess I'm looking for a solution on what is happening at work because that is the one that seems to Couse the issues, I have been using Fusion at work and home for years and until now things started to give me issues.
To Resume:
1-Work computer had a warning "Unable to validate a security certificate"
2-Was there for a week or so
3-Then fusion was not able to start "not connected to internet" or something like that
4-Followed the instructions to do a "clean uninstall" and reinstalled Fusion - and it worked again..BUT...
5-The warning "Unable to validate a security certificate" still there
6-AND now....When try to access from home it says that a session is on use so I have to "suspend" the other session
7-This never happened before
8-I'm 100% sure Work PC Fusion is not running and checked task manager to see if fusion was running somehow on the background but is not ( I have remote access to my PC at work)
9-I checked my work PC for other errors for the server or any problems with other software and all seems Ok
10-Server IT said there is no Proxy
11-I checked for Virus and run Malwarebytes for any other Issues but all returned Ok
Thank you
