I'm not sure if this is new or existing behavior(I have been away from fusion for a bit), but when editing parameters in any of the input dialog, even something like "change parameters", pressing the escape key immediate cancel the dialog. Loosing any of the other properties that have been set up.
It is normal UI practice that in a dialog, when and input field such as a text entry field has focus and in edit mode, hitting escape first cancels the edit on this field at which point hitting escape again might close the dialog. The current behavior means that if you click on a text field to change its value, clicking escape immediately aborts the whole operation instead of just aborting the text edit and reverting it to its previous value. This cause frequent redo such reselecting a bunch of items.
