Announcements
Circular pattern parameter
Hello i have a circular band that i have made using parameters and i have added a hole 2mm at one point. I would like to pattern this hole around the band using parameters so when i update the size of tube the number of holes increases or decreases accordingly. Is there an equation that can calculate that? Ive tried to use degrees but maybe im writing the parameter incorrectly.
Also im aware circular patterning needs a whole number so im curious if its possible to have a fuction that rounds down/up to the nearest whole number.
Thank you! Been messing around but my maths is rusty.
jeff_strater
In theory, this should be easy - just use a user parameter for the hole diameter, then pattern the hole using Pattern on Path.  You should be able to change the number of pattern instances based on hole diameter using Ceil() or Floor(), but you will have to make sure that the result is unitless, usually by dividing by 1mm or whatever your length unit is.
Jeff Strater
Engineering Director
jhackney1972
Here is an example.  I did not use an units in the parameter table, as I added the units as needed in the various dimensions.  You can vary any of the parameters you desire, the two marked are probably the ones you want to vary the most.  By the way, when rounding the hole spacing, I rounded down.  If you want to round up, change "floor" to "ceil".  Model attached.
John Hackney, Retired
jeff_strater
here is another version.  It is obviously not for a ring, but hopefully illustrates the basic ideas.  This parameterizes a block, a hole, and the pattern, with spacing.
I have not tested this extensively for bullet-proofing, but hopefully it gets the ideas across
Jeff Strater
