Announcements
Circular pattern check boxes not lining up with instance they control.
While watching Brad Tallis' Fusion 360 training video on the Autodesk Fusion 360 YouTube channel, I noticed a software behavior that appears to be a bug. When creating a circular pattern, the new instances do not line up with the suppression check boxes that control them. It appears that the original feature is receiving the check box and the last instance of the pattern does not. I created my own simple model to see if I could duplicate the same problem and experienced the same issue. This appears to be a bug. Thanks
https://youtu.be/IMyqBEjrJWI?t=1485
g-andresen
I could not recreate the described behaviour in multiple actions.
Can you share your file to have a look at it?
günther
If you edit the circular pattern you will see that the original instance has a control node associated with it and that one of the pattern instances does not. Thanks for taking a look.
g-andresen
1. with your file I could see the described behaviour
2. various tests with new files and also after restarting the application showed both the incorrect and the expected (correct) behaviour.
3. connected with the error is also a deviating position of the checkboxes. The markers appear near the centre when the error is displayed and not next to the instances.
günther
