Circular Dependency Error report requested by Autodesk
msw135morgan
msw135morgan
Above error has start appearing in a design which is in 319th version.  It even shows up in version saved 8 months ago, had not appeared previously.  Fusion suggested that I "Please report this error to Autodesk!"   Here it is.   This error has made it impossible to make changes in the design, short of turning off design history.   The error is occasionally accompanied by reference to  extrusion21 (a simple rectangular extrusion) and a "mirror" with no indication of which mirror.  The design has a lot of mirror operations.
"Break Link operation will be aborted due to cyclic dependency error.  Please report this issue to Autodesk!"
yogesh.mahajanUS36Y
Hello @msw135morgan Extremely sorry that you are facing this. Can you please help us with the Diagnostics logs from your machine, right after you face this problem? If possible, please invite me to your project  yogesh.mahajan@autodesk.com.
msw135morgan
Hi Yogesh.mahajanUS36Y,  Please see attached diagnostics file.   It is not clear how to invite you to the project or alternatively send you a link to the project, as I cannot tell what the email is.   Although I am happy to share with you/Autodesk for diagnostic information, I cannot share the link at large on the forum as the design is proprietary.
Regards,   Morgan
