Circles, lines, squares wont resize when entering dimensions while creating them
Its the same issue as this post https://forums.autodesk.com/t5/fusion-360-support/circles-squares-wont-rezise-when-entering-the-dime...
Except none of it applies to my situation, im running windows 10 on the latest update with the latest fusion 360 and yet im running into this issue and its driving me mad. I thought this was only something that affected older versions of windows but apparently not.
Whenever I try to create a circle I enter the dimension and it gets highlighted in blue in the box, then a small lock appears next to it, when I press enter, instead of using the dimension given it just uses the dimension of the random circle before entering the dimension.
I'm not sure when this issue started cropping up but now its happening every single time I try and draw anything, I could use the method in the above thread but that takes significantly longer and just serves to make everything more tedious.
Is their some setting I need to change or is it just a fundamental issue with the program?
I've included a recording of the issue below.
