Fusion Support
Circles displayed jagged - How to fix ?
2 REPLIES 2
matthewYCCK4
126 Views, 2 Replies
In fusion 360 two circle bodies will show their outline jagged - The actual diameter will be 80mm but will look more like an octagon (see image to get a better understanding of what I mean) its disorientating and makes me think my models are not the same size and not aligned - This is clearly a rendering issue, any ideas how to fix this or is this an error with an update ?
Labels (2)
2 REPLIES 2
jhackney1972
in reply to: matthewYCCK4
Please attach your model shows the issue you describe.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
g-andresen
change your "Display Detail" settings to FIXED > Level > high
günther
