Announcements
Circle tangent points in drawing
rajugupta8200
rajugupta8200
I want to apply a dimension of slot, but unable to identify the top and bottom points in drawing workspace.
 I want to identify the top and bottom points of a slot for applying a total 50 mm length dimension, but I am only able to apply the center to center distance and radius only.
For that I tried to apply center mark pattern but unable to achieve.
Is there any alternate option for applying a total dimension of a slot ?
Marco.Takx
Hi @rajugupta8200,
You can dimension it like this.
See attachment video.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
rajugupta8200
Thanks for the help
