You posted on the Autodesk Fusion 360 Support Forum so I guess you want to know if Fusion 360 is compatible with Chromebook. The answer is no. I do not think any full version Autodesk applications are designed to run on it either.
John Hackney, Retired
Fusion 360 has a limited Web front-end.
I can't seem to find the "open in web browser" option in the project drop down anymore.....has there been a change?
