Fusion Support
Choosing Multiple Depths Using 2D Contour Not Working
3 REPLIES 3
in10semtb
137 Views, 3 Replies
New to Fusion, so bare with me. I have a simple .080" thick ABS sheet, 5" x 7". Starting out safe in the beginning till I get comfortable with the CAM side. I want to do multiple passes at .020" each using 2D Contour, till it reaches full depth of .080". When I do a simulation, it looks like it's milling from the bottom up, but hard to tell. Hope that makes sense, and what simple setting am I missing?
3 REPLIES 3
HughesTooling
in reply to: in10semtb
Can you export the design as an F3D and share here?
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Don't suppose you are running the simulation backwards?
The speed control point needs to be to the right of the middle.
Mark Hughes
in10semtb
Found out...... per other forum messages, had simulation running in reverse. What's interesting is that it came up by default like that, in reverse. Sorry for the dumb question, and thanks to the forum!!
