I am trying to make a hole in a piece of wood. The bit has a 17mm (0.66 inch) cut length but the hole needs to be 0.85". The issue is that the 2D adaptive toolpath is drilling down to depth and then making large circles from there. What happens is that by this time, the bit is deeper than the cutting length, so the top of the bit acts as a bearing (like on a router pattern bit). What I need is some way to tell it to work totally top to bottom. It needs to cut out the entire hole, then move a little deeper, then move a little deeper, until the hole is complete. Is there a way to do that? Thank you
