Changing text height in drawing space freezes fusion
jack.scolding
jack.scolding
Hi
I have been getting this issue for the past year I have been using fusion 360. when I am in the drawing space and change the font size i will freeze fusion. it doesn't happen every time but it happens enough to ruin my work flow. especially as it does not save any recovery files so anything not saved is gone. Below is what I do which causes the issue.
-Place a text box and type your text (do not click out of the box)
-Highlight the Text just typed
-Highlight the Text Size in the Prompt and Delete the old size
-Type in the new size (this should trigger the freeze)
are there any fixes thanks
ClintBrown3D
Hi @jack.scolding
Thanks for reporting this, I'll pass it on to the development team to investigate. Would you be able to send us an F3Z of one of the drawings where this issue has occurred, for us to have a look at? You can attach the F3Z file here, or if it is sensitive, feel free to send it directly to me Clint. Brown {a} Autodesk.com
Clint Brown
Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
