Changing sketch dimension may result in a shadow profile
I think this might be a bug. I have an M2.5 panhead machine screw (attached). I can edit the sketch and change the 5mm
outer diameter to, say, 4mm and that works ok. Edits like that are usually fine - I think I ran into issues because I was creating M3,M4 etc screws from an original design and I was hopping around checking dimensions.
I can get Fusion 360 into a state where the sketch will show a ghost of the previous diameter. For example there are three extrusions in the design I attached:
- Right click the centre one and edit feature. Cancel. Sometimes now the first item in the timeline, the sketch is highlighted. Now I can't right click on it. Not sure this is a big deal. This action seems to matter though when getting a shadow to appear...
- Then I edit the sketch (in the browser) and change 5mm to 4mm. Now I get this:
There's a shadow profile around the outside. That profile isn't based on anything other than something that used to be there and now isn't! But I can now stop the sketch. And if I click on the sketch in the timeline I can see that the ghost is still there. I can even extrude from it too, mostly accidentally!
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thanks for sharing this - I get the same results as you as well! To be honest, not too sure why this is happening, all I know is that it shouldn't be. I've gone ahead and logged this with development (FUS-37569). I'd be curious to see what might be going on. I'll keep experimenting as well to see if we can't get that ghost profile to disappear.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
James Youmatz
General Adoption Manager | Informed Design
Xierion
I've had the same thing in a few of my models and previously the sketches weren't overly complicated so I have redrawn them from scratch. My latest instance was on a more complicated sketch so as a test I saved the design as a new file, closed, and re-opened and the ghost profile was no longer there.
