Hi
I'm trying to generate linked copies of a body in a circular pattern so that I can edit just ONE of them, and the changes will apply to all of them. However, this is not happening. If I change the first body, the other copied ones don't change.
Select body -> Circular Pattern -> OK -> Modify original body -> The change only applies to the original (copies don't change)
What am I doing wrong here? I suspect it's just a workflow issue on my part
See attached video
Thank you 😊
