Change pivot point when rotating part of a form in 'Edit form'
iefHFYA7
iefHFYA7
Hi there,
I'm looking for a way to change the pivot point when rotating part of an object. I'm editing a form with the edit form menu.
See screenshot. The actual pivot point is nr. 1, it's the centre of the selected part of the body. But I want it to be at nr. 2.
Ief
davebYYPCU
In your picture, there is a value box, with 1.00 in it,
on the right hand end of that box, is the triad icon, selecting it, unlocks the pivot and allows reposition to other locations, while it is movable that icon changes to a green tick icon, and when the new position is set, you must click on the green tick, for the actual triad to be set.
Might help...
jeff_strater
Here is what @davebYYPCU is referring to.  This icon lets you change the pivot point,  Just don't forget to click the green check icon that will take you out of "set pivot" mode.
Jeff Strater
Engineering Director
iefHFYA7
Allright, that's easy! Thanks Jeff and Dave!
