Change Parametrs window do not appear
pulcik
pulcik
I can not open the "Change parametrs" menu / window. When I click on the button, F360 seems to do something in background, as I am not able to access the history for a few second, and then everything works as it should, but the window does not pop up.
I don't know, if it is a bug in latest update, or am I missing something?
Fusion 360 2.0.16976 x86_64
Active Plan: Student
Windows 10 Home 22H2 (19045.3324)
jhackney1972
I am guessing it is related to your graphics.  Try changing the Fusion 360 Graphics Driver and see if it helps.  I will caution you, if you change the driver, Fusion 360 must be restarted, be sure to save your work first.
John Hackney, Retired
pulcik
This doesn't solve it. Plus, other pop-ups are working.
I will try it at home,  if it is only on this computer of mine. And might reinstall fusion, if it is.
