Change language Fusion 360 mobile app
waterjetZXA5D
waterjetZXA5D
Hello
How can I change language in the mobile app??? I get it in espanol/spanish and cant find how to change to english. 🤯
pawel.potyrala
Hi @waterjetZXA5D,
thanks for posting. For Android, the application language settings are automatically adjusted to fit those of the device. To change them from Spanish to English, go to Ajustes -> Idiomas e introduccion de texto -> Idiomas -> ...
If you are referring to the Fusion 360 Hub in the Web Browser, here's an instruction on how to change it for Google Chrome.
Does it work differently for you?
Thanks in advance!
Best regards,
Paweł Potyrała
Technical Support Manager
Global Product Support
My Screencasts | Fusion 360 Webinars
waterjetZXA5D
Hello
Thanks but Ive got an iPhone. Cant find anywhere in the Fusion app. And my phone has defoult language swedish and english.
pawel.potyrala
Hi @waterjetZXA5D,
thanks for the reply. I just tested this on iOS as well. By design, the language of the Fusion 360 Mobile Application should also be changed by adjusting the language settings for the phone: Settings -> General -> Language and Region -> English.
The following languages are supported: English , French , Spanish , German, Italian , Japanese, Russian , Portuguese, Korean, Turkish, Chinese (simplified and traditional).
While Swedish is not on the list, English should be selected by default.
I am curious to know what happens when you try the following:
  1. Select English as the first device language: Settings -> General -> Language and Region -> English
  2. Run Fusion 360 to check if the language has been changed
  3. Select Swedish as the first device language: Settings -> General -> Language and Region -> Swedish
  4. Repeat 2.
Thanks in advance!
Best regards,
Paweł Potyrała
waterjetZXA5D
Hello
Ok thanks that work. I had both swedish and spanish. Obviously that dont work.
pawel.potyrala
Hi @waterjetZXA5D,
thanks for the message! I am happy to know it worked.
Best regards,
Paweł Potyrała
convrtx009
To change the language:
  1. Go to Settings -> General -> Language and Region.
  2. Select the desired language.
  3. Save the settings
