Announcements
Change in Draft Command
wmhazzard
wmhazzard
I am not happy with the latest change in the draft command. For some reason now we have a preset box at the top of the dialog box that opens up with Fusion 360 Default, I click on the drop down box and select last used, make my draft and close. Next face that needs draft, open draft again and once again I have to change from Fusion default to last used, EVERY TIME. What is the logic behind that? And on top of that I still can't do a symmetric draft or a parting line draft on the end of a cylinder which I brought up nearly two years ago now.
https://forums.autodesk.com/t5/fusion-360-support/draft-fail/m-p/9377424
wmhazzard
Finally clicked enough of the buttons to find the set default as last used button. I guess it wasn't important enough to include on the what's new page.
