Change Default Render Camera
hoptownhandles
hoptownhandles
I prefer to render designs with the orthographic camera instead of perspective.  The camera used to remain orthographic for all new designs, but now, whenever I start a new design or leave the render workflow, the camera reverts to perspective mode.  It is very annoying to have to switch the camera every single time we want to do a rendering.  Is there a way to set the default camera to ortho?  I would suspect it should be in the below screen, but it isn't there.  Any help here?  Thanks!
ryan.bales
Autodesk Support
Autodesk Support
No there is no way to do this by default, though i would agree this is a good idea to have as an option - even if i rarely render in ortho.
Ryan Bales
Fusion 360 Product Support
ryan.bales
Autodesk Support
Autodesk Support
Actually, i think there is a related defect as the Scene settings allows you to change to ORTHO but it doesn't save. So that theoretically should work AND we should have a drop down in settings in my opinion.
Ryan Bales
