Chamfer, Slope or some other method
mcarr67
mcarr67
I would like to create a chamfer or slope where the red line is,  and the drawing to the right. I cannot figure out how to accomplish this. Any advice?
jhackney1972
Please attach your model so the Forum users can help you out.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
wmhazzard
If the chamfer tool will not do what you want then sketch the little red triangle on an intersecting plane coincident to the inside edge of the circle and revolve.
