Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Chain and Sprocket Modeling
Does Fusion 360 support chain and sprocket motion.?  I saw a YouTube where these can be copied from the McMaster catalog, but I don't see where anyone has successfully put the chain in motion around sprockets. Can we do this?
jhackney1972
Fusion 360 does support the assembly joints necessary to show chain and sprocket motion.  You place the sprockets and then wrap them with a "fake" chain.  You then add Joints to the sprockets and "Motion Links" between these joints.  Here is an article on adding and using Motion Links.
I have attached a screencast of an Autodesk Inventor chain and sprocket assembly just to show you that this application also fakes the chain since to actually model it, which can be done,  and animating it would take way to much system resources.
John Hackney, Retired
TrippyLighting
You also posted this in the other part of the forum. Please do not cross post!
1. Thanks for reply.
2. I didn’t know that it took twice. I didn’t see the first one in the list, so I did it again. I’m sorry. New to this.
