Certain text characters not properly centering within text box. Bug?
I've been playing with the sketch text function and have found that while most characters will properly center themselves horizontally and vertically in my sketch as designed, a few characters will bizarre move to the right.
Could someone please confirm if this is a bug or unexpected behavior?
Screencast and model attached.
(You'll see in the model I've also been having fun exploring the user parameters function and parametric modeling in general.)
As an aside (I'm mostly just venting at this point), in the process if playing with these functions, I've also already encountered the following previously documented bugs or unexpected behaviors:
- Parametric formulas require you to cancel out the dimensions. Ex. d2 + d2 will work but d2 * d2 will not. You must use d2 * (d2 / 1 in).
- Sketch text height will accept a parametric input but it only loads in the raw value upon initial setup and does not update.
- You cannot use driven dimensions as parameters for other dimensions (hence why I have a user parameter expression of "( 2 * sqrt(( ( 0.5 * d1 / 1 in ) ^ 2 ) - ( ( ( d6 / 1 in ) + ( d33 / 1 in ) + 0.5 * ( d2 / 1 in ) ) ^ 2 )) ) * 1 in")
Screencast link because I keep getting the "Your post has been changed because invalid HTML was found in the message body." bug when I try to embed it: https://knowledge.autodesk.com/community/screencast/77119bba-e4ef-406e-bbe0-e3b5a2f04d9d
