Fusion Support
Centering hole on a constructed axis?
6 REPLIES 6
eliJUZP6
118 Views, 6 Replies
Fusion 360 noob here,
Is there a way to center this hole on the axis I constructed?
6 REPLIES 6
jhackney1972
in reply to: eliJUZP6
Please attach your model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
TheCADWhisperer
@eliJUZP6
Does the Axis occur in history before or after the Hole?
(Parent/child relationships.  Can you exist in history before your mom.  Or did your mom exist first?)
eliJUZP6
in reply to: jhackney1972
Here is the file
eliJUZP6
in reply to: TheCADWhisperer
Before the hole
eliJUZP6
Before the hole
jhackney1972
See a possible solution in Message #4 in this Forum post.
John Hackney
Retired
