Center point arc creating the wrong segment
I wanted to create a small cylinder with raised text. Not particularly easy with this software but I found a good tutorial about it. The process is to create a arc that is not completely closed. Using sheetmetal setting so it has a wall thickness. extrude it out. created a small extrusion on the edge of the open segment of the cylinder to create a flat surface to unfold the circle with, create the raised text on the flat part and refold.
I Can't get past creating the arc!!! I start my center point, denote my desired radius, click on a starting point, enter the degree value for the arc. In my case, i chose 358 degrees to give me an opening large enough to be able to highlight the face of the edge. When I create the arc, the program created an arc that is only 2 degrees! The drawing is a minute line that goes from the start to the end instead of around and making almost an entire circle.
1. Is there a better way to create a cylinder with raised text?
2. Why won't it draw the larger circle?
The only way i have been able to draw it is to draw a 180 degree circle and then attach a 178 degree circle attached to it. seems ridiculous to me
