Capture Position for Joint Angles?
I have a small series of 6 components linked together by revolute Joints.
I would like to modify all 6 revolute joints, then capture their joint angles (similar to capture position), then change the joint angles to a different configuration, then save the joint angles again etc.
The goal is to quickly go from one joint configuration to the next without having to manually change each revolute joint every time.
I tried using the Capture Position function, but it does not show after changing joint angles.
H
