Announcements
Canvas
Geeraard.Ceulemans
Canvas
Geeraard.Ceulemans
When i insert a photo to fusion the aspect ratio is not correct, enclosed the picture and screenshot
g-andresen
Right-click on the canvas (in Browsertree)  > Edit Canvas > Edit X & Y independently
günther
artemSIV
Hello, this simple example will help you figure out how to scale and rotate canvas. Good luck to you.
I tried to add 410x210px proper aligned image to get a  41x21mm design, but the aspect ratio is not 1:1  when you import the image. Because my image's object has squares I can calibrate from there using x y separately, but if object has curves it's impossible to calibrate.
