Steps to reproduce:
Create a canvas on a face.
Create a sketch, start tracing around the canvas (which is 50 times harder than Corel Draw's Bezier curves btw)
Save it..
Go back in and edit sketch - canvas is GONE WTF? OH, lookey here, the history shows that you created the Canvas after the sketch... Totally crazy, but OK, clearly, I didn't, but whatever... Drag and drop it back to where it belongs... BUZZ! Wrong answer, you can't do that because Fusion 360 doesn't want you to!
Ok, Drag the sketch to the top of the history... BUZZ!!! Wrong Answer, can't do that either...
OK, Delete project and recreate it from scratch again...
Yep! That is a Fusion 360 compatible solution that I've had to use way too many times...
(OK, a bit of sarcasm there, but this is what it did to me, after spending 30 minutes trying to draw 15 arcs around a stupid image, that I could have done in Corel Draw in 2 minutes or so.. but instead, I have two points around the arcs and you change one and all the others change too... in Corel Draw I can move one end of the curve and it only affects that curve (two end points and it is done, not all the points that come into that, but that is another topic)
Starting over with the project, unless there is a way to
