Fusion Support
Cant update
1 REPLY 1
ryderpcamp
77 Views, 1 Reply
Cant update
When I try to open my models it says that I need the latest version of Fusion to open them, but when I click the clock icon to see updates there's nothing there.
1 REPLY 1
@ryderpcamp Here is what you can do.
1. Delete the Fusion 360 short cut you have currently (This is an important step as we have seen some shortcuts that trigger some problems)
2. While launching Fusion 360 (I assume this is windows) click on Ctrl+shift to launch the Fusion 360 service utility (you have to click on the keys while Fusion is launching. If for some reason this does not work go to Add/remove programs - select Fusion 360 - change/modify)
3. Run a repair of Fusion 360
This will take you to the latest version and also create a new short cut that you can use.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
