Announcements
Cant seem to draw a line of 0.75mm
stevekennedyuk
stevekennedyuk
I'm trying to draw a line of 0.75mm (so when the shape is revolved it will be 1.5mm), however F360 is snapping to 0.7 or 0.8mm.
I've tried everything and can't seem to find a solution.
Thnaks
Steve
Replies (13)
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post
günther
TheCADWhisperer
@stevekennedyuk
Fortunately this is any easy one. (As easy as anything gets in CAD.)
I would turn off snap to grid and use parametric dimensions instead.
As mentioned by @g-andresen
jeff_strater
It sounds like you might need to turn off snapping, and use the in-command dimension to specify the length;
Screenshot 2023-03-20 at 8.20.31 AM.pngScreenshot 2023-03-20 at 8.21.58 AM.png
Jeff Strater
Engineering Director
stevekennedyuk
Even if I type .75mm it turns it to 0.8mm and when scaled up the dimensions disappear off screen
TheCADWhisperer
@stevekennedyuk
Your screenshot does not show any dimensions?
Never mind - I found it.
What do you have General Precision set to in Preferences?
@stevekennedyuk
I am going to recommend that you take about 10 steps back and start over.
Create a new file.
1. Sketch one (and only one) line at a time anchored with one end at the Origin.
2. Immediately dimension the line.
3. What do you observe about the color of the line after dimensioning?
Now, repeat 1-3 for next line connected to either origin or previous line.
Now, repeat 1-3 for next line.
If at any time you see white dots or blue lines (or arcs) on your screen after dimensioning - STOP- and ask questions here before proceeding.
And make sure that you have Show Constraints enabled (as well as Dimensions).
stevekennedyuk
I'm on a Mac. Even if I type 0.75mm it does a line of 0.8mm, I tried turning precision to 0.12 (was at 0.1)
stevekennedyuk
OK. the measurement is 0.75, it's displayed at 0.8
TheCADWhisperer
1. Your image is showing the wrong preferences. (You are showing Drawing rather than Design Preferences.)
2. You did not Attach new file here.
Click on your avatar upper right corner of screen...
Go to Preferences...
g-andresen
please check
günther
stevekennedyuk
That worked, even though it's showing 0.8mm it's measured at 0.75mm
Next problem, add a thread to the cylinder and it's showing in Fusion but doesn't seem to be exported to STL
g-andresen
1. enable "modeled"
2. If you have set the number of decimal places correctly in the preferences, the display will also be correct.
3. It is not clear from your post which reply it refers to.
Please answer directly to replies and not via the quick reply.
This way you answer yourself.
günther
stevekennedyuk
Apologies completely missed the modelled option, perfect, all working now!!!
g-andresen
Note: The accepted solution is set for the contribution that led to the solution.
günther
