Announcements
cant save a project.
bineesha.mini
Observer Observer
bineesha.mini
Observer
Observer
Last day when I was saving my project it showed some message that I didn't bothered to look and press yes for that. After that it showed me to update a component in my project (Catridge  3 phase). Updating it, eventually replaced that file with an another existing file (Stepper 3 phase with linear actuator)  in the project. Which in-terms induced a lot of errors in my timeline. Because the earlier component was used as a reference for many other. So what I did to solve the errors was to replace the component by its original one (By right click-> Replace component). It indeed solved the errors in timeline. But after that, I am not able to save the project. It is showing the error massage ->   Error: The source asset FusionAssetName in document Final Assembly 3 v24 has not referenced the target asset FusionAssetName in document Stepper Motor with Linear Actuation v3! .
Please help.
sutherland-
Hi @bineesha.mini
Do you have any text within the sketches?
If yes, do the following:
Make sure Fusion is updated.
or
Remove any text from sketches within the assembly.
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
