Cant reinstall Fusion360
felix_geitmann003
Observer Observer
felix_geitmann003
Observer
Observer
Hi, i cant reinstall Fusion and i dont know what the problem is.
The first mistake i made is, i tried to uninstall Fusion360 in i think the wrong way. after that i tried to install Fusion360 from the website but then this erro occurs.
dooyoul_chung
Hi @felix_geitmann003
Please try below steps to install Fusion.
1. Make sure that Fusion installer is not running in task manager
2. Go to %localappdata%\Autodesk\ then DELETE the following folders – Webdeploy, Web Services, Identity services, Autodesk Fusion 360 ((IF you do not have any other Autodesk products installed, delete the Full Autodesk folder)
3. Delete the shortcut that is used to launch Fusion
4. Restart your machine
5. Do not use the same Fusion installer. Can you please download the installer again
6. Now install again
