cant open fusion
donaldkaiser47
cant open fusion
donaldkaiser47
i have a new install and after i try to open fusion it said its not responding then it has a box saying there is issues
Replies (20)
RajkumarIlanchelian
@donaldkaiser47 @Can you post the image of the UI that shows what the issue is?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
donaldkaiser47
I don’t know what UI is but it is saying log in issue and at the bottom  it says connection issue
RajkumarIlanchelian
@donaldkaiser47 Can you post an image of the error?
Autodesk Fusion
Join Fusion Insider
donaldkaiser47
Here the screen shot
donaldkaiser47
Can’t you open fusion with out internet
RajkumarIlanchelian
@donaldkaiser47
Can you please try the below?
  1. Close Fusion
  2. Go to  C:\Users\<USER>\AppData\Local\Autodesk\Identity Services\idservices.db
Can you delete the idervices.db file and then restart Fusion?
Autodesk Fusion
Join Fusion Insider
donaldkaiser47
I can’t find the directions that you put on her
RajkumarIlanchelian
@donaldkaiser47 Are you referring to this?
  1. Go to  C:\Users\<USER>\AppData\Local\Autodesk\Identity Services\idservices.db
Autodesk Fusion
Join Fusion Insider
donaldkaiser47
I don’t have appdata
RajkumarIlanchelian
@donaldkaiser47 Its likely you have those as hidden folders. Do a google search to show hidden folders in Windows and you should see it.
Autodesk Fusion
Join Fusion Insider
donaldkaiser47
I got in the program but it’s on a free trial and I have a hobbyist account that don’t expire until December of this year
RajkumarIlanchelian
@donaldkaiser47 Glad you are able to launch now. Can you confirm that you are using the same email ID/account used to register for the hobby account? Can you send me the email ID used in a direct message?
Autodesk Fusion
Join Fusion Insider
donaldkaiser47
Donaldkaiser47@gmail.com
RajkumarIlanchelian
@donaldkaiser47 Thank you and just to confirm this is the only email ID you have used to create an account, right? More so this is the email ID you gave to get the hobby license, correct?
Autodesk Fusion
Join Fusion Insider
donaldkaiser47
It was the right account the stuff I was working was in there
donaldkaiser47
Yes
RajkumarIlanchelian
@donaldkaiser47 While I get help to look at the backend can you login to https://login.autodesk360.com/login and tell me if it shows up as a trial account?
Autodesk Fusion
Join Fusion Insider
donaldkaiser47
It said I’m on a trial period
how do I get it switch to a hobbyist account
RajkumarIlanchelian
@donaldkaiser47 Going to check with out backend team on this.
Autodesk Fusion
Join Fusion Insider
