cant install, uninstall or open fusion 360
hi, i have 360 installed but unable to open it as there is no .exe anywhere to find, so i go to install it and it tells me i already have it installed, so i try and uninstall it but even with 3rd party programs can not see the install anywhere to remove it, below is the copy paste of my log file, hopefuly you can help me
2023-12-01 10:04:45,942 - MainProcess(10172) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\alexb\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2023-12-01 10:04:45,943 - MainProcess(10172) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2023-12-01 10:04:45,943 - MainProcess(10172) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 10:04:45,943 - MainProcess(10172) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000020E31128610> #
2023-12-01 10:04:45,944 - MainProcess(10172) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 10:04:45,944 - MainProcess(10172) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-01 10:04:45,944 - MainProcess(10172) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\alexb\AppData\Local\Temp\7zS3D6B.tmp\resources\buildinfo.json
2023-12-01 10:04:45,944 - MainProcess(10172) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2023-12-01 10:04:45,944 - MainProcess(10172) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20231122000000
2023-12-01 10:04:45,944 - MainProcess(10172) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_GB
2023-12-01 10:04:45,945 - MainProcess(10172) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\alexb\AppData\Local\Temp\7zS3D6B.tmp\resources
2023-12-01 10:04:45,946 - MainProcess(10172) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\alexb\AppData\Local\Temp\7zS3D6B.tmp\certs.pem
2023-12-01 10:04:45,947 - MainProcess(10172) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2023-12-01 10:04:45,947 - MainProcess(10172) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2023-12-01 10:04:45,948 - MainProcess(10172) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2023-12-01 10:04:45,948 - MainProcess(10172) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x0000020E31110FE0>, operation=<function multiple_operate at 0x0000020E307F5440>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2023-12-01 10:04:45,948 - MainProcess(10172) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2023-12-01 10:04:45,948 - MainProcess(10172) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2023-12-01 10:04:45,948 - MainProcess(10172) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2023-12-01 10:04:45,948 - MainProcess(10172) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2023-12-01 10:04:46,479 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2023-12-01 10:04:46,566 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2023-12-01 10:04:47,039 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2023-12-01 10:04:47,039 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.registry - INFO :: Failed to query database schema, initializing.
2023-12-01 10:04:47,046 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2023-12-01 10:04:47,046 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2023-12-01 10:04:47,046 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2023-12-01 10:04:47,047 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2023-12-01 10:04:47,047 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\alexb\AppData\Local\Autodesk\check_perm
2023-12-01 10:04:47,047 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\alexb\AppData\Local\Autodesk\check_perm created successfully
2023-12-01 10:04:47,047 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\alexb\AppData\Local\Autodesk\check_perm
2023-12-01 10:04:47,047 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\alexb\AppData\Local\Autodesk\check_perm removed successfully
2023-12-01 10:04:47,047 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\alexb\AppData\Local\Autodesk
2023-12-01 10:04:47,047 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2023-12-01 10:04:47,047 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2023-12-01 10:04:47,047 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2023-12-01 10:04:47,081 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:47,081 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:47,081 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:47,081 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2023-12-01 10:04:47,081 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2023-12-01 10:04:47,082 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 104.82.197.165
2023-12-01 10:04:47,092 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2023-12-01 10:04:47,094 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0LjgyLjE5Ny4xNjU=
2023-12-01 10:04:47,094 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjY0
2023-12-01 10:04:47,094 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2023-12-01 10:04:47,094 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2023-12-01 10:04:47,134 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000020E3112B810>
2023-12-01 10:04:47,134 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2023-12-01 10:04:47,143 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2023-12-01 10:04:47,143 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.82.197.165
2023-12-01 10:04:47,143 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-01 10:04:47,143 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-01 10:04:47,169 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:47,169 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:47,169 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:47,232 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2023-12-01 10:04:47,233 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2023-12-01 10:04:47,233 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2023-12-01 10:04:47,233 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2023-12-01 10:04:47,263 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:47,263 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:47,263 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:47,321 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000020E3116B150>
2023-12-01 10:04:47,322 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2023-12-01 10:04:47,352 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2023-12-01 10:04:47,352 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.82.197.165
2023-12-01 10:04:47,378 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:47,378 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:47,378 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:47,430 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000020E3116AA90>
2023-12-01 10:04:47,430 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2023-12-01 10:04:47,430 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2023-12-01 10:04:47,431 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2023-12-01 10:04:47,457 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:47,457 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:47,457 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:47,495 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000020E3116AED0>
2023-12-01 10:04:47,496 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2023-12-01 10:04:47,505 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2023-12-01 10:04:47,505 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.82.197.165
2023-12-01 10:04:47,505 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-01 10:04:47,505 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-01 10:04:47,531 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:47,531 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:47,531 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:47,582 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2023-12-01 10:04:47,582 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2023-12-01 10:04:47,582 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2023-12-01 10:04:47,582 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-01 10:04:47,582 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-01 10:04:47,608 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:47,608 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:47,608 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:47,653 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is 3ebb4aa6-2d91-4524-8e35-a314dfb4a734
2023-12-01 10:04:47,654 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.17954 for app 73e72ada57b7480280f7a6f4a289729f
2023-12-01 10:04:47,654 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2023-12-01 10:04:47,654 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2023-12-01 10:04:47,654 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2023-12-01 10:04:47,697 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version found.
2023-12-01 10:04:47,697 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 1b891e3c161b456cb570ff9a05c8a9c8(INITIAL_INSTALL_DELETE_FILES)
2023-12-01 10:04:47,702 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 8448384f7771a48f527d0845e10c53c508347ee4
2023-12-01 10:04:47,702 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/8448384f7771a48f527d0845e10c53c508347ee4.js...
2023-12-01 10:04:47,727 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:47,727 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:47,728 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:47,792 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/b3e7c38b9fa0cf16c5b745442eef962f633a92a4.ta... for package 8448384f7771a48f527d0845e10c53c508347ee4
2023-12-01 10:04:47,792 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: f47e23cb0dd0e8c3da8112223dab0de68894e6fb
2023-12-01 10:04:47,792 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/f47e23cb0dd0e8c3da8112223dab0de68894e6fb.js...
2023-12-01 10:04:47,824 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:47,824 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:47,824 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:47,834 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:47,834 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:47,834 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:47,880 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/9a9f3521924dbeee4f35ae2aa8a31e5b7c1a7673.ta... for package f47e23cb0dd0e8c3da8112223dab0de68894e6fb
2023-12-01 10:04:47,880 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: f9d72584a7ccd644d61a1070fa8d631a25baa508
2023-12-01 10:04:47,880 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/f9d72584a7ccd644d61a1070fa8d631a25baa508.js...
2023-12-01 10:04:47,928 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:47,928 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:47,929 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:47,931 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:47,931 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:47,931 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:47,933 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:04:47,933 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path does not exist. Creating
2023-12-01 10:04:48,018 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:04:48,068 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/4fbade619bd03d6fdfacc8372cfbf45a9a219a58.ta... for package f9d72584a7ccd644d61a1070fa8d631a25baa508
2023-12-01 10:04:48,068 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: f1299b03727981443b84f9cb8842a2a50499a632
2023-12-01 10:04:48,069 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/f1299b03727981443b84f9cb8842a2a50499a632.js...
2023-12-01 10:04:48,102 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:48,102 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:48,102 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:48,112 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:48,112 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:48,112 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:48,263 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:04:48,278 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/bacd9bee7bc9277e39136e2f5be27fc7bed68b2f.ta... for package f1299b03727981443b84f9cb8842a2a50499a632
2023-12-01 10:04:48,278 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: eb09053acccba626ac5debcebe7c4d34c82e7d05
2023-12-01 10:04:48,292 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/eb09053acccba626ac5debcebe7c4d34c82e7d05.js...
2023-12-01 10:04:48,313 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:48,313 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:48,313 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:48,323 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:48,323 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:48,323 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:48,709 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:04:48,726 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:04:48,858 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:04:49,033 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 18180e76f6d8de6e431e982f0aab427a865e140c
2023-12-01 10:04:49,033 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/18180e76f6d8de6e431e982f0aab427a865e140c.js...
2023-12-01 10:04:49,033 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/93c81a1b82d19b22671dd42634baca10467ef50f.ta... for package eb09053acccba626ac5debcebe7c4d34c82e7d05
2023-12-01 10:04:49,068 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:49,068 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:49,068 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:49,077 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:49,078 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:49,078 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:49,154 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: f9b89be5c7b7977b3281b839507b10025b1f0cc6
2023-12-01 10:04:49,154 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ab824c5c9838756a960af66aa86228a12f52c40a.ta... for package 18180e76f6d8de6e431e982f0aab427a865e140c
2023-12-01 10:04:49,154 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/f9b89be5c7b7977b3281b839507b10025b1f0cc6.js...
2023-12-01 10:04:49,187 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:04:49,198 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:49,198 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:49,198 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:49,201 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:49,201 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:49,201 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:49,361 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: c0c60505751edf3ce14cddea85fc502b6248f688
2023-12-01 10:04:49,362 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c0c60505751edf3ce14cddea85fc502b6248f688.js...
2023-12-01 10:04:49,389 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:49,389 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:49,389 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:49,570 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 83a0e411d5e359dc273d94ed2e06ed55a1c502f6
2023-12-01 10:04:49,570 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/83a0e411d5e359dc273d94ed2e06ed55a1c502f6.js...
2023-12-01 10:04:49,597 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:49,597 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:49,597 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:49,775 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: c975f886560950304f11ff1b6e0e573db6edd66d
2023-12-01 10:04:49,775 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c975f886560950304f11ff1b6e0e573db6edd66d.js...
2023-12-01 10:04:49,802 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:49,802 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:49,802 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:49,983 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:04:50,335 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:04:50,335 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e978b8bb5bf4e41ffacdfb3aaa2f6cb704080299.ta... for package f9b89be5c7b7977b3281b839507b10025b1f0cc6
2023-12-01 10:04:50,363 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:50,363 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:50,363 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:50,423 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 429197af20b934df594c14b53975255b09bab97e
2023-12-01 10:04:50,423 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/429197af20b934df594c14b53975255b09bab97e.js...
2023-12-01 10:04:50,452 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:50,453 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:50,453 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:50,491 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:04:50,578 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 22f0ec0d8e16724c93eeb28814589c2b373d4a83
2023-12-01 10:04:50,578 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/22f0ec0d8e16724c93eeb28814589c2b373d4a83.js...
2023-12-01 10:04:50,622 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:50,623 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:50,623 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:51,101 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: b3210048ef2054a5a32f15e9e7912f1f0c2d6545
2023-12-01 10:04:51,101 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b3210048ef2054a5a32f15e9e7912f1f0c2d6545.js...
2023-12-01 10:04:51,128 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:51,129 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:51,129 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:51,688 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:04:51,688 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d1af43d1d2538f708829378c919d88449e61bc02.ta... for package c0c60505751edf3ce14cddea85fc502b6248f688
2023-12-01 10:04:51,715 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:51,716 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:51,716 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:51,758 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:04:51,849 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 9587cd629d084fdf205e6bf9c170c7125f7fe33d
2023-12-01 10:04:51,849 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/9587cd629d084fdf205e6bf9c170c7125f7fe33d.js...
2023-12-01 10:04:51,876 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:51,876 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:51,876 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:52,053 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: f27e8edebdda4d8a67b3a53667fb4912f4a9162e
2023-12-01 10:04:52,053 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/f27e8edebdda4d8a67b3a53667fb4912f4a9162e.js...
2023-12-01 10:04:52,080 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:52,081 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:52,081 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:52,103 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:04:52,105 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/89ac0f1f1a64079cb64fe00862cee9aea0a14487.ta... for package 83a0e411d5e359dc273d94ed2e06ed55a1c502f6
2023-12-01 10:04:52,132 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:52,132 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:52,132 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:52,233 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 19090bf5efc7b82faffaaf993de69ffb3a4dd8d8
2023-12-01 10:04:52,233 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/19090bf5efc7b82faffaaf993de69ffb3a4dd8d8.js...
2023-12-01 10:04:52,263 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:52,264 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:52,264 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:52,306 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:04:52,413 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: e72eac6166edafdc5bc7bc96ad11cec07ebfca14
2023-12-01 10:04:52,413 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e72eac6166edafdc5bc7bc96ad11cec07ebfca14.js...
2023-12-01 10:04:52,441 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:52,441 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:52,441 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:52,502 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:04:52,503 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f4ef165cbacab8ea2d4f6b990d9c1dc4f4c42959.ta... for package c975f886560950304f11ff1b6e0e573db6edd66d
2023-12-01 10:04:52,529 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:52,530 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:52,530 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:52,593 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 503953f23ee2b7ea98d95ad29510f775079ca37e
2023-12-01 10:04:52,593 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/503953f23ee2b7ea98d95ad29510f775079ca37e.js...
2023-12-01 10:04:52,621 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:52,621 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:52,621 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:52,660 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:04:52,705 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: bdf5f828404c59af756de01e99b6f6ffb3d4da3d
2023-12-01 10:04:52,706 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/bdf5f828404c59af756de01e99b6f6ffb3d4da3d.js...
2023-12-01 10:04:52,738 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:52,738 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:52,739 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:53,176 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: ccb9b4ffe027b5fa0623f44e0f8a86fbf8a0a0d3
2023-12-01 10:04:53,176 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/ccb9b4ffe027b5fa0623f44e0f8a86fbf8a0a0d3.js...
2023-12-01 10:04:53,208 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:53,208 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:53,208 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:53,248 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:04:53,249 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1b13f151406e9e5fd4a4f0be9d6acb188839931c.ta... for package 429197af20b934df594c14b53975255b09bab97e
2023-12-01 10:04:53,283 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: e911d548da767ec1dc351b5990c9a556e0fddd26
2023-12-01 10:04:53,283 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e911d548da767ec1dc351b5990c9a556e0fddd26.js...
2023-12-01 10:04:53,300 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:53,300 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:53,300 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:53,311 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:53,312 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:53,312 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:53,368 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:04:53,376 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 3e5e194a6b803bda06f96b96e4238a38007abd47
2023-12-01 10:04:53,376 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/3e5e194a6b803bda06f96b96e4238a38007abd47.js...
2023-12-01 10:04:53,410 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:53,410 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:53,410 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:53,463 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:04:53,464 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/fb3bbaa323ad23f25c307537eca451dec5466772.ta... for package 22f0ec0d8e16724c93eeb28814589c2b373d4a83
2023-12-01 10:04:53,490 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:53,490 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:53,490 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:53,957 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:04:54,160 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: cbb3675fafbbd97c576525bd628450b411a2b1ef
2023-12-01 10:04:54,160 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/cbb3675fafbbd97c576525bd628450b411a2b1ef.js...
2023-12-01 10:04:54,188 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:54,188 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:54,188 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:54,332 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:04:54,333 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2ee7cb9ff75507c98e49516251f6c96b71f7d5e0.ta... for package b3210048ef2054a5a32f15e9e7912f1f0c2d6545
2023-12-01 10:04:54,354 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 66b1a9e045ad7faae5745672857dd81cd9513203
2023-12-01 10:04:54,354 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/66b1a9e045ad7faae5745672857dd81cd9513203.js...
2023-12-01 10:04:54,370 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:54,371 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:54,371 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:54,380 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:54,380 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:54,380 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:54,462 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 410fb71474b87a60adda9476f2369385e7d539d8
2023-12-01 10:04:54,462 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/410fb71474b87a60adda9476f2369385e7d539d8.js...
2023-12-01 10:04:54,478 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:04:54,489 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:54,489 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:54,489 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:54,535 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:04:54,536 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/5109217c843892893fcc4ef57b0963a1008c2342.ta... for package 9587cd629d084fdf205e6bf9c170c7125f7fe33d
2023-12-01 10:04:54,561 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:54,561 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:54,562 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:54,675 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: ef71691fc03b9bfe393a787d7238c4a3f13ad5cb
2023-12-01 10:04:54,675 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/ef71691fc03b9bfe393a787d7238c4a3f13ad5cb.js...
2023-12-01 10:04:54,703 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:54,703 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:54,704 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:54,860 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: ef15d74705aae519a4bb55ab33647b54442f13f1
2023-12-01 10:04:54,860 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/ef15d74705aae519a4bb55ab33647b54442f13f1.js...
2023-12-01 10:04:54,888 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:54,888 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:54,888 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:55,448 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:04:55,689 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: e5b60f15cceaf30083d05c3dea795a799e5665ea
2023-12-01 10:04:55,690 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e5b60f15cceaf30083d05c3dea795a799e5665ea.js...
2023-12-01 10:04:55,719 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:55,719 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:55,719 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:56,312 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:04:56,313 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/4b406ba9ef4b47d6583c3d3dcdf805b80e5129c0.ta... for package f27e8edebdda4d8a67b3a53667fb4912f4a9162e
2023-12-01 10:04:56,338 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:56,338 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:56,338 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:56,351 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 3994ef5c397cdfe37541503e333a4a390a5eff8f
2023-12-01 10:04:56,351 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/3994ef5c397cdfe37541503e333a4a390a5eff8f.js...
2023-12-01 10:04:56,377 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:56,377 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:56,377 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:56,420 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:04:56,470 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:04:56,470 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/a46a64fae992314a7e5d52ed6afd6a5cfc29fe7f.ta... for package 19090bf5efc7b82faffaaf993de69ffb3a4dd8d8
2023-12-01 10:04:56,496 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:56,496 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:56,496 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:56,497 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 4e77ab2ae8dd4a3f1773f5516e96bd2e1e806dcd
2023-12-01 10:04:56,497 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/4e77ab2ae8dd4a3f1773f5516e96bd2e1e806dcd.js...
2023-12-01 10:04:56,524 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:56,524 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:56,525 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:56,542 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:04:56,543 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/600bec389de3c5a177fa3400db2804a693aa7d29.ta... for package e72eac6166edafdc5bc7bc96ad11cec07ebfca14
2023-12-01 10:04:56,570 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:56,570 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:56,570 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:56,579 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: bd27dfce780626fe4ceccb4dd4ca267597ee5151
2023-12-01 10:04:56,579 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/bd27dfce780626fe4ceccb4dd4ca267597ee5151.js...
2023-12-01 10:04:56,595 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:04:56,606 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:56,606 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:56,606 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:56,759 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 8fc098769a2b8a0204dff52aac01c9258b04d683
2023-12-01 10:04:56,759 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/8fc098769a2b8a0204dff52aac01c9258b04d683.js...
2023-12-01 10:04:56,776 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:04:56,786 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:56,786 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:56,786 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:57,560 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 635d3cd0959f516509c05e48bca8b4552ff2b2dc
2023-12-01 10:04:57,560 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/635d3cd0959f516509c05e48bca8b4552ff2b2dc.js...
2023-12-01 10:04:57,587 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:57,587 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:57,587 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:57,771 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 67b62ded3169893ad39c8987f9e04737cec50bf9
2023-12-01 10:04:57,771 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/67b62ded3169893ad39c8987f9e04737cec50bf9.js...
2023-12-01 10:04:57,796 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:57,796 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:57,796 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:57,847 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:04:57,848 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1c62faf4736bcf97c0e1b5fd296a84f8f3f178d2.ta... for package 503953f23ee2b7ea98d95ad29510f775079ca37e
2023-12-01 10:04:57,883 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:57,883 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:57,883 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:57,903 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: eedfe3251233c571f70195d73e6673f5486f32e4
2023-12-01 10:04:57,903 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/eedfe3251233c571f70195d73e6673f5486f32e4.js...
2023-12-01 10:04:57,931 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:57,931 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:57,931 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:57,946 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:04:58,021 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: dd54cc9d2b41180ea3f81101cec060e0fbcafd9f
2023-12-01 10:04:58,021 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/dd54cc9d2b41180ea3f81101cec060e0fbcafd9f.js...
2023-12-01 10:04:58,048 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:58,049 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:58,049 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:58,418 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:04:58,419 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/548272041da70c6e2e3ff69c28402146ff49b984.ta... for package bdf5f828404c59af756de01e99b6f6ffb3d4da3d
2023-12-01 10:04:58,448 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:58,448 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:58,448 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:58,543 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:04:58,714 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 73c592c74ab19b6ca3e301a07569f7497b02d380
2023-12-01 10:04:58,714 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/73c592c74ab19b6ca3e301a07569f7497b02d380.js...
2023-12-01 10:04:58,744 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:58,744 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:58,744 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:58,932 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: cb3c524a531e26b56e9873c24cc57bb56604acc8
2023-12-01 10:04:58,932 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/cb3c524a531e26b56e9873c24cc57bb56604acc8.js...
2023-12-01 10:04:58,959 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:58,959 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:58,959 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:59,125 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: feb2db168757a03e3c6ae3651ea5126d8febebbc
2023-12-01 10:04:59,125 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/feb2db168757a03e3c6ae3651ea5126d8febebbc.js...
2023-12-01 10:04:59,154 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:59,154 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:59,154 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:59,304 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 5c567f46b36668461f291d0b730651ce5bfc782f
2023-12-01 10:04:59,304 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/5c567f46b36668461f291d0b730651ce5bfc782f.js...
2023-12-01 10:04:59,332 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:59,332 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:59,332 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:59,503 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 7b950498fc3ac93faf7f46bd95de01a4a8be487b
2023-12-01 10:04:59,503 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/7b950498fc3ac93faf7f46bd95de01a4a8be487b.js...
2023-12-01 10:04:59,537 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:59,537 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:59,537 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:59,685 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 526693d9f6b3b90b9c32c1dfc4807f3efc652e26
2023-12-01 10:04:59,685 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/526693d9f6b3b90b9c32c1dfc4807f3efc652e26.js...
2023-12-01 10:04:59,713 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:59,713 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:59,713 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:04:59,882 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: fd3bc24fb0918545b269ae8da321e8d894c63aa7
2023-12-01 10:04:59,882 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/fd3bc24fb0918545b269ae8da321e8d894c63aa7.js...
2023-12-01 10:04:59,909 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:04:59,909 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:04:59,909 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:00,054 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 8b74479e7a54644b1f416d099776ef32bc2c34a1
2023-12-01 10:05:00,054 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/8b74479e7a54644b1f416d099776ef32bc2c34a1.js...
2023-12-01 10:05:00,080 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:00,080 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:00,080 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:00,230 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 1a770a48d6a9cf17b653ae43d2bc455e8ba997eb
2023-12-01 10:05:00,230 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1a770a48d6a9cf17b653ae43d2bc455e8ba997eb.js...
2023-12-01 10:05:00,258 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:00,258 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:00,258 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:00,406 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: cd398d360d746179da04a19fe608256034f75a64
2023-12-01 10:05:00,406 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/cd398d360d746179da04a19fe608256034f75a64.js...
2023-12-01 10:05:00,445 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:00,445 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:00,445 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:00,539 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:05:00,541 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/897d6df14d8fdb2f2028c883984307e2be97a030.ta... for package ccb9b4ffe027b5fa0623f44e0f8a86fbf8a0a0d3
2023-12-01 10:05:00,565 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: fb4c55ed2663d9a3f2eb28da6f60792b22a35639
2023-12-01 10:05:00,565 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/fb4c55ed2663d9a3f2eb28da6f60792b22a35639.js...
2023-12-01 10:05:00,582 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:00,582 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:00,582 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:00,591 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:00,592 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:00,592 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:00,667 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 7cdfef548c5a41c52596927fcd47bc6f32bb9090
2023-12-01 10:05:00,667 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/7cdfef548c5a41c52596927fcd47bc6f32bb9090.js...
2023-12-01 10:05:00,683 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:05:00,696 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:00,696 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:00,696 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:00,960 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:05:00,961 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f55b866443281a72c8072835423eafdefd94e801.ta... for package e911d548da767ec1dc351b5990c9a556e0fddd26
2023-12-01 10:05:00,995 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:00,996 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:00,996 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:01,104 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:05:01,104 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f571dbbb16336a93ae4fb444e1d5468597976a16.ta... for package 3e5e194a6b803bda06f96b96e4238a38007abd47
2023-12-01 10:05:01,121 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:05:01,134 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:01,134 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:01,134 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:01,335 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:05:01,807 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 08eac89f9fcad63010170837e2011dcd49d8230c
2023-12-01 10:05:01,807 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/08eac89f9fcad63010170837e2011dcd49d8230c.js...
2023-12-01 10:05:01,835 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:01,835 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:01,835 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:02,499 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: c3a19ec53e408415a798386917886e0d2252e3ea
2023-12-01 10:05:02,499 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c3a19ec53e408415a798386917886e0d2252e3ea.js...
2023-12-01 10:05:02,526 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:02,526 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:02,526 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:02,968 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 99ebf4ed6b3214119eeabeba58ac2f4656c3749e
2023-12-01 10:05:02,968 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/99ebf4ed6b3214119eeabeba58ac2f4656c3749e.js...
2023-12-01 10:05:03,003 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:03,003 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:03,003 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:03,403 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: a567df632148f3e6831d18aca5c1efa8e9428a51
2023-12-01 10:05:03,403 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/a567df632148f3e6831d18aca5c1efa8e9428a51.js...
2023-12-01 10:05:03,433 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:03,433 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:03,433 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:04,264 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 3c95a5a1cb0e50a6e0b0e66ce4f1726cad890f0e
2023-12-01 10:05:04,264 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/3c95a5a1cb0e50a6e0b0e66ce4f1726cad890f0e.js...
2023-12-01 10:05:04,292 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:04,292 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:04,292 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:04,695 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 95190f27fd4c9397eb899e5e2d68d9588d8b6b5b
2023-12-01 10:05:04,695 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/95190f27fd4c9397eb899e5e2d68d9588d8b6b5b.js...
2023-12-01 10:05:04,723 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:04,723 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:04,723 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:06,024 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 7afa45cadee95b425e4f4e0e42bfa5c3db823d9e
2023-12-01 10:05:06,024 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/7afa45cadee95b425e4f4e0e42bfa5c3db823d9e.js...
2023-12-01 10:05:06,054 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:06,054 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:06,054 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:06,421 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: c962179509c8630aed96b173eee01c1e11137184
2023-12-01 10:05:06,421 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c962179509c8630aed96b173eee01c1e11137184.js...
2023-12-01 10:05:06,451 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:06,451 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:06,451 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:07,402 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 831018f04309093474438aa0acbaf990290f6cae
2023-12-01 10:05:07,402 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/831018f04309093474438aa0acbaf990290f6cae.js...
2023-12-01 10:05:07,430 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:07,430 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:07,430 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:08,027 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: b52270c742f3cc4d7ecc2f28e590aeab65411055
2023-12-01 10:05:08,027 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b52270c742f3cc4d7ecc2f28e590aeab65411055.js...
2023-12-01 10:05:08,061 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:08,061 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:08,061 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:08,221 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 1e23f39fce7bce012c7896905e9812b1fd308f6f
2023-12-01 10:05:08,221 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1e23f39fce7bce012c7896905e9812b1fd308f6f.js...
2023-12-01 10:05:08,256 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:08,256 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:08,256 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:08,656 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: b3c4465887ba56d69af092a443b467e15fe91bb7
2023-12-01 10:05:08,656 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b3c4465887ba56d69af092a443b467e15fe91bb7.js...
2023-12-01 10:05:08,683 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:08,683 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:08,683 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:08,833 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 7eb4f6b582973401e2ddb7d44c33c347ef2fdaee
2023-12-01 10:05:08,833 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/7eb4f6b582973401e2ddb7d44c33c347ef2fdaee.js...
2023-12-01 10:05:08,860 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:08,861 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:08,861 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:09,316 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 620add78c887bb1d1755397b98a1f0a94e886cb8
2023-12-01 10:05:09,317 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/620add78c887bb1d1755397b98a1f0a94e886cb8.js...
2023-12-01 10:05:09,344 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:09,345 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:09,345 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:10,099 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 2972d451293a075a2be62782f760dbff1547ae39
2023-12-01 10:05:10,099 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/2972d451293a075a2be62782f760dbff1547ae39.js...
2023-12-01 10:05:10,126 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:10,126 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:10,126 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:10,816 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 5a8a326a0bd0537927a92e8c634d574f1796d018
2023-12-01 10:05:10,816 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/5a8a326a0bd0537927a92e8c634d574f1796d018.js...
2023-12-01 10:05:10,842 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:10,842 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:10,842 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:11,204 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:05:11,206 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/4cd2c89c0597c6867e36070fa4622c96804255ad.ta... for package cbb3675fafbbd97c576525bd628450b411a2b1ef
2023-12-01 10:05:11,238 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:11,238 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:11,238 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:11,299 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:05:12,008 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Start executing tasks thread
2023-12-01 10:05:12,008 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 8448384f7771a48f527d0845e10c53c508347ee4
2023-12-01 10:05:12,021 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for f47e23cb0dd0e8c3da8112223dab0de68894e6fb
2023-12-01 10:05:12,042 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for f9d72584a7ccd644d61a1070fa8d631a25baa508
2023-12-01 10:05:12,047 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for f1299b03727981443b84f9cb8842a2a50499a632
2023-12-01 10:05:12,051 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for eb09053acccba626ac5debcebe7c4d34c82e7d05
2023-12-01 10:05:12,068 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 18180e76f6d8de6e431e982f0aab427a865e140c
2023-12-01 10:05:12,072 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for f9b89be5c7b7977b3281b839507b10025b1f0cc6
2023-12-01 10:05:12,078 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for c0c60505751edf3ce14cddea85fc502b6248f688
2023-12-01 10:05:12,086 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 83a0e411d5e359dc273d94ed2e06ed55a1c502f6
2023-12-01 10:05:12,090 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for c975f886560950304f11ff1b6e0e573db6edd66d
2023-12-01 10:05:12,096 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 429197af20b934df594c14b53975255b09bab97e
2023-12-01 10:05:12,100 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 22f0ec0d8e16724c93eeb28814589c2b373d4a83
2023-12-01 10:05:12,105 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for b3210048ef2054a5a32f15e9e7912f1f0c2d6545
2023-12-01 10:05:12,110 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 9587cd629d084fdf205e6bf9c170c7125f7fe33d
2023-12-01 10:05:12,115 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for f27e8edebdda4d8a67b3a53667fb4912f4a9162e
2023-12-01 10:05:12,121 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 19090bf5efc7b82faffaaf993de69ffb3a4dd8d8
2023-12-01 10:05:12,126 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for e72eac6166edafdc5bc7bc96ad11cec07ebfca14
2023-12-01 10:05:12,131 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 503953f23ee2b7ea98d95ad29510f775079ca37e
2023-12-01 10:05:18,881 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:05:18,883 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ff26319131e06d384b985be7d4a2b20e432ef979.ta... for package 66b1a9e045ad7faae5745672857dd81cd9513203
2023-12-01 10:05:18,911 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:18,911 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:18,911 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:19,203 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:05:33,614 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:05:33,616 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/a1e73273185235d0c66dafd13c9042ef8ce3fca2.ta... for package 410fb71474b87a60adda9476f2369385e7d539d8
2023-12-01 10:05:33,643 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:33,643 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:33,644 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:33,776 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:05:39,829 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:05:39,831 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/a95b0e978751a34a7db89a36961fa98817641526.ta... for package ef71691fc03b9bfe393a787d7238c4a3f13ad5cb
2023-12-01 10:05:39,859 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:39,859 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:39,859 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:39,930 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:05:39,936 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:05:39,936 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/cba397190ab950c13effed4f0baab76d8f679f14.ta... for package ef15d74705aae519a4bb55ab33647b54442f13f1
2023-12-01 10:05:39,963 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:39,963 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:39,963 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:40,039 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:05:42,374 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:05:42,375 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2a3ede364f09999e2e21921a67487e9988084473.ta... for package e5b60f15cceaf30083d05c3dea795a799e5665ea
2023-12-01 10:05:42,392 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for bdf5f828404c59af756de01e99b6f6ffb3d4da3d
2023-12-01 10:05:42,403 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:42,404 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:42,404 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:42,404 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for ccb9b4ffe027b5fa0623f44e0f8a86fbf8a0a0d3
2023-12-01 10:05:42,501 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:05:42,677 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:05:42,677 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/318036ead2cea97acb36a621eacefc1bb9a6d5c9.ta... for package 3994ef5c397cdfe37541503e333a4a390a5eff8f
2023-12-01 10:05:42,703 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:42,703 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:42,703 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:42,850 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:05:45,439 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:05:45,441 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/aa483441a1eae28014f2eb89ca58a72eb0f259e0.ta... for package 4e77ab2ae8dd4a3f1773f5516e96bd2e1e806dcd
2023-12-01 10:05:45,468 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:45,468 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:45,468 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:45,700 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:05:46,016 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:05:46,017 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/148245316ff60b820dd435d2ea3946d44350a67a.ta... for package bd27dfce780626fe4ceccb4dd4ca267597ee5151
2023-12-01 10:05:46,043 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:46,043 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:46,043 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:46,131 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:05:46,226 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:05:46,227 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/fa9c1eeac036a1e37595ad9edb285d9301e9230b.ta... for package 8fc098769a2b8a0204dff52aac01c9258b04d683
2023-12-01 10:05:46,244 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for e911d548da767ec1dc351b5990c9a556e0fddd26
2023-12-01 10:05:46,255 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:46,256 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:46,256 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:46,257 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 3e5e194a6b803bda06f96b96e4238a38007abd47
2023-12-01 10:05:46,507 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:05:47,024 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:05:47,025 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/618f1f47a054efebdbff8b197fff55fef70333f2.ta... for package 635d3cd0959f516509c05e48bca8b4552ff2b2dc
2023-12-01 10:05:47,052 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:47,052 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:47,052 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:47,199 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:05:47,515 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:05:47,516 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/34a076456ba6053cdda9e8d93eb2fc5aa1485127.ta... for package 67b62ded3169893ad39c8987f9e04737cec50bf9
2023-12-01 10:05:47,541 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:47,541 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:47,542 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:47,667 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:05:48,510 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:05:48,510 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ad5234db68556fb886ebd076afda7d2a50e12849.ta... for package eedfe3251233c571f70195d73e6673f5486f32e4
2023-12-01 10:05:48,536 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:48,536 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:48,536 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:48,612 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:05:48,637 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:05:48,637 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/251ff10c9eea826cbda831557df9cece90675413.ta... for package dd54cc9d2b41180ea3f81101cec060e0fbcafd9f
2023-12-01 10:05:48,665 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:48,665 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:48,665 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:48,731 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:05:50,877 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:05:50,879 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/9d81b01fdac72f2eb826d9a7ddb21ae203261f17.ta... for package dd54cc9d2b41180ea3f81101cec060e0fbcafd9f
2023-12-01 10:05:50,908 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:50,908 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:50,908 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:50,996 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:05:52,092 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:05:52,093 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/73c592c74ab19b6ca3e301a07569f7497b02d380.ta... for package 73c592c74ab19b6ca3e301a07569f7497b02d380
2023-12-01 10:05:52,120 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:05:52,120 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:05:52,121 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:05:52,295 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\Common
2023-12-01 10:05:52,296 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path does not exist. Creating
2023-12-01 10:06:16,866 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:06:16,868 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/b19a118d3fc7a3c27020511cc321266f3b2ff43d.ta... for package cb3c524a531e26b56e9873c24cc57bb56604acc8
2023-12-01 10:06:16,888 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for cbb3675fafbbd97c576525bd628450b411a2b1ef
2023-12-01 10:06:16,897 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:06:16,897 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:06:16,897 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:06:16,921 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 66b1a9e045ad7faae5745672857dd81cd9513203
2023-12-01 10:06:16,986 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:06:17,021 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 410fb71474b87a60adda9476f2369385e7d539d8
2023-12-01 10:06:17,027 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for ef71691fc03b9bfe393a787d7238c4a3f13ad5cb
2023-12-01 10:06:17,033 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for ef15d74705aae519a4bb55ab33647b54442f13f1
2023-12-01 10:06:17,038 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for e5b60f15cceaf30083d05c3dea795a799e5665ea
2023-12-01 10:06:17,043 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 3994ef5c397cdfe37541503e333a4a390a5eff8f
2023-12-01 10:06:17,072 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 4e77ab2ae8dd4a3f1773f5516e96bd2e1e806dcd
2023-12-01 10:06:17,078 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for bd27dfce780626fe4ceccb4dd4ca267597ee5151
2023-12-01 10:06:17,191 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:06:17,191 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/34e3ef0cc7e64cd3ef0a1d6331bd677f6be05051.ta... for package feb2db168757a03e3c6ae3651ea5126d8febebbc
2023-12-01 10:06:17,217 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:06:17,217 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:06:17,218 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:06:17,418 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:06:28,185 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:06:28,187 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1783064665ce00600d0bfe6531625b5e977e9116.ta... for package 5c567f46b36668461f291d0b730651ce5bfc782f
2023-12-01 10:06:28,215 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:06:28,215 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:06:28,215 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:06:28,340 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:06:28,900 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:06:28,901 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/97535e5a5ef9457181e9634625d3b7ed39a34915.ta... for package 7b950498fc3ac93faf7f46bd95de01a4a8be487b
2023-12-01 10:06:28,927 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:06:28,928 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:06:28,928 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:06:28,975 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:06:49,183 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:06:49,185 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/71e6cb675291cf8ed6aa88fc27f8317eb8135b28.ta... for package 526693d9f6b3b90b9c32c1dfc4807f3efc652e26
2023-12-01 10:06:49,211 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:06:49,211 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:06:49,211 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:06:49,375 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:06:58,288 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:06:58,290 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/7e01facb0c7bbb050eee06c7fcb228cc62faca03.ta... for package fd3bc24fb0918545b269ae8da321e8d894c63aa7
2023-12-01 10:06:58,324 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:06:58,324 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:06:58,324 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:06:58,417 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:07:13,765 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:07:13,769 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/13067041b0b033850124a00539688ed300a2b6ab.ta... for package 8b74479e7a54644b1f416d099776ef32bc2c34a1
2023-12-01 10:07:13,801 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:07:13,802 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:07:13,802 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:07:13,996 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:07:17,172 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:07:17,174 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/be99a76bd29aacf7b6a533c0f2a41778a25256af.ta... for package 1a770a48d6a9cf17b653ae43d2bc455e8ba997eb
2023-12-01 10:07:17,205 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:07:17,206 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:07:17,206 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:07:17,268 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:07:18,978 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:07:18,979 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/4d6da65a99a64c8963dc6d819c2507912d7d10b3.ta... for package 1a770a48d6a9cf17b653ae43d2bc455e8ba997eb
2023-12-01 10:07:19,006 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:07:19,006 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:07:19,006 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:07:19,132 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:07:19,260 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:07:19,260 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/cd398d360d746179da04a19fe608256034f75a64.ta... for package cd398d360d746179da04a19fe608256034f75a64
2023-12-01 10:07:19,288 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:07:19,288 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:07:19,288 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:07:19,435 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2023-12-01 10:07:19,436 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path does not exist. Creating
2023-12-01 10:07:19,592 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:07:19,592 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ec6a151762f22898847717a22b9118bb5bbf729e.ta... for package fb4c55ed2663d9a3f2eb28da6f60792b22a35639
2023-12-01 10:07:19,622 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:07:19,622 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:07:19,622 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:07:19,781 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:07:24,566 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:07:24,568 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/5a36e4f0045709e7afb97278ed9804d76b86dca3.ta... for package 7cdfef548c5a41c52596927fcd47bc6f32bb9090
2023-12-01 10:07:24,600 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:07:24,600 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:07:24,600 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:07:24,657 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:07:26,187 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:07:26,188 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/af24f2391e5610166cf23578ed8201835503b58a.ta... for package 08eac89f9fcad63010170837e2011dcd49d8230c
2023-12-01 10:07:26,231 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:07:26,231 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:07:26,231 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:07:26,293 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:07:27,281 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:07:27,281 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/70257d089d6d5f111493827c41d341941ae29d3d.ta... for package c3a19ec53e408415a798386917886e0d2252e3ea
2023-12-01 10:07:27,309 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:07:27,309 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:07:27,309 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:07:27,396 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:07:42,767 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:07:42,768 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/084861b2a1cc31df648d50b1959b5c22c1738cdb.ta... for package c3a19ec53e408415a798386917886e0d2252e3ea
2023-12-01 10:07:42,795 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:07:42,795 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:07:42,795 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:07:42,888 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:07:43,787 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:07:43,788 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f21103ad886fe8658fb7e2a6138b01854aa01afa.ta... for package 99ebf4ed6b3214119eeabeba58ac2f4656c3749e
2023-12-01 10:07:43,814 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:07:43,814 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:07:43,814 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:07:43,901 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:08:09,464 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:08:09,465 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/db85e00c8c50c8d82b644b0475930706676a617c.ta... for package a567df632148f3e6831d18aca5c1efa8e9428a51
2023-12-01 10:08:09,465 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 8fc098769a2b8a0204dff52aac01c9258b04d683
2023-12-01 10:08:09,466 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 7facf0de95414ab9b6315d8fa534bf91(INSTALL_WEBVIEW2)
2023-12-01 10:08:09,466 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Detecting if WebView2 needs to be installed
2023-12-01 10:08:09,481 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: WebView2 found in Local Machine
2023-12-01 10:08:09,482 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action a92c95fa064f43089136f50437f73d22(UPDATE_IDSDK_CONFIG)
2023-12-01 10:08:09,482 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.platform_base - INFO :: Update config ssoServer property
2023-12-01 10:08:09,482 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.platform_base - INFO :: Found Configuration file : C:/Users/alexb/AppData/Local/Autodesk/webdeploy/production/b0c303e70bd97cfdc195adab65922cfeffcb363a/Autodesk Identity Manager/AdskIdentityManagerInstall.config
2023-12-01 10:08:09,483 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.platform_base - INFO :: Configuration updated successfully
2023-12-01 10:08:09,483 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package 8fc098769a2b8a0204dff52aac01c9258b04d683
2023-12-01 10:08:09,484 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 8fc098769a2b8a0204dff52aac01c9258b04d683
2023-12-01 10:08:09,495 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:08:09,496 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:08:09,496 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:08:09,502 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 635d3cd0959f516509c05e48bca8b4552ff2b2dc
2023-12-01 10:08:09,511 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 67b62ded3169893ad39c8987f9e04737cec50bf9
2023-12-01 10:08:09,521 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for eedfe3251233c571f70195d73e6673f5486f32e4
2023-12-01 10:08:09,569 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:08:09,636 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:08:09,636 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/423c6c9363f8fc5d37723b9632997bd1c253d8a2.ta... for package 3c95a5a1cb0e50a6e0b0e66ce4f1726cad890f0e
2023-12-01 10:08:09,661 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:08:09,661 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:08:09,661 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:08:09,816 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:08:17,273 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:08:17,277 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/6164d0df77807693ea4f0ddbccecbc06db447494.ta... for package 3c95a5a1cb0e50a6e0b0e66ce4f1726cad890f0e
2023-12-01 10:08:17,278 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package dd54cc9d2b41180ea3f81101cec060e0fbcafd9f
2023-12-01 10:08:17,292 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 3af6a9fa26704d868bb90e12b3aed9be(EXTERNAL_INSTALLS)
2023-12-01 10:08:17,295 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 5c461fa5ff6ec38afa078cf537137159(ADD_REGISTRY_INFO)
2023-12-01 10:08:17,310 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:08:17,310 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:08:17,310 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:08:17,404 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - WARNING :: Could not export subkey: Command '['C:\\Windows\\System32\\reg.exe', 'export', 'HKCU\\Software\\Classes\\CLSID\\{C4F0910E-E0B4-4E68-8086-452730C7A26A}', 'C:\\Users\\alexb\\AppData\\Local\\Temp\\tmp_bf2gzop', '/y']' returned non-zero exit status 1.
2023-12-01 10:08:17,435 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:08:17,484 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - WARNING :: Could not export subkey: Command '['C:\\Windows\\System32\\reg.exe', 'export', 'HKCU\\Software\\Classes\\.f3d', 'C:\\Users\\alexb\\AppData\\Local\\Temp\\tmpi851ccp7', '/y']' returned non-zero exit status 1.
2023-12-01 10:08:17,485 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 1f397ebf8d2a4ca9befc3072340f035e(FILESYSTEM_ACTIONS)
2023-12-01 10:08:17,485 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 31e0f47eabdd436bb829e0c65acf67ba(CREATE_PACKAGE_LINK)
2023-12-01 10:08:17,486 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action 36d909d4c5304fc2a6a47bbb9116f50e(REMOVE_STREAMING_SESSION) was not in registry
2023-12-01 10:08:17,486 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package dd54cc9d2b41180ea3f81101cec060e0fbcafd9f
2023-12-01 10:08:17,487 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for dd54cc9d2b41180ea3f81101cec060e0fbcafd9f
2023-12-01 10:08:17,766 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:08:17,767 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/84139fc94453aef5feb3b3693db6ec905ebed59f.ta... for package 95190f27fd4c9397eb899e5e2d68d9588d8b6b5b
2023-12-01 10:08:17,799 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:08:17,799 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:08:17,800 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:08:17,914 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:08:17,934 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 73c592c74ab19b6ca3e301a07569f7497b02d380
2023-12-01 10:08:17,934 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 1f397ebf8d2a4ca9befc3072340f035e(FILESYSTEM_ACTIONS)
2023-12-01 10:08:17,934 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 3af6a9fa26704d868bb90e12b3aed9be(EXTERNAL_INSTALLS)
2023-12-01 10:08:17,943 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.platform_base - INFO :: Executing: "\\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\MaterialLibraryMigrator.exe" "migratecache" "C:\Users\alexb\AppData\Local\Autodesk\Common\Material Library"
2023-12-01 10:08:18,125 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action c1d5a6c7dcbf4562b683600beeae3d5f(REMOVE_TEMP_MATERIAL_FOLDER) was not in registry
2023-12-01 10:08:18,125 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package 73c592c74ab19b6ca3e301a07569f7497b02d380
2023-12-01 10:08:18,126 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 73c592c74ab19b6ca3e301a07569f7497b02d380
2023-12-01 10:08:18,180 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for cb3c524a531e26b56e9873c24cc57bb56604acc8
2023-12-01 10:08:18,198 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for feb2db168757a03e3c6ae3651ea5126d8febebbc
2023-12-01 10:08:18,384 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:08:18,385 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/994f22ad8b6ec28d528fb9b791c130f7bff0021b.ta... for package 7afa45cadee95b425e4f4e0e42bfa5c3db823d9e
2023-12-01 10:08:18,415 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:08:18,416 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:08:18,416 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:08:18,548 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:08:18,672 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:08:18,672 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/bb1f67ac60736be479e73ab6847c78c911b5b60c.ta... for package c962179509c8630aed96b173eee01c1e11137184
2023-12-01 10:08:18,693 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 5c567f46b36668461f291d0b730651ce5bfc782f
2023-12-01 10:08:18,706 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:08:18,706 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:08:18,707 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:08:18,713 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 7b950498fc3ac93faf7f46bd95de01a4a8be487b
2023-12-01 10:08:18,847 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:08:18,900 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 526693d9f6b3b90b9c32c1dfc4807f3efc652e26
2023-12-01 10:08:19,386 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:08:19,388 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e938a4c1bb8f7de4316c30f1d10e827313e57c00.ta... for package c962179509c8630aed96b173eee01c1e11137184
2023-12-01 10:08:19,414 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:08:19,414 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:08:19,414 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:08:19,933 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:08:20,228 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:08:20,229 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d68e2e7f7dd92d3a025c008138b686c9ea0c279a.ta... for package 831018f04309093474438aa0acbaf990290f6cae
2023-12-01 10:08:20,256 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:08:20,256 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:08:20,256 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:08:20,415 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:08:23,375 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:08:23,376 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/cbe34babeebdbcdd83dc1d5a2f3a4c12aa0bcf62.ta... for package b52270c742f3cc4d7ecc2f28e590aeab65411055
2023-12-01 10:08:23,405 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:08:23,405 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:08:23,405 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:08:23,470 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:08:25,213 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:08:25,214 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/8e1e149fc606620e9b4dd1599f267f8b7c35dd53.ta... for package b52270c742f3cc4d7ecc2f28e590aeab65411055
2023-12-01 10:08:25,251 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:08:25,251 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:08:25,251 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:08:25,406 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:08:25,601 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:08:25,601 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/112a84403ff2f496da9711d2311446f030e8bab8.ta... for package 1e23f39fce7bce012c7896905e9812b1fd308f6f
2023-12-01 10:08:25,640 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:08:25,640 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:08:25,640 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:08:25,773 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:08:26,134 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:08:26,134 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/6930eb1bc7065da1202f3b49305e697ccfefcc30.ta... for package b3c4465887ba56d69af092a443b467e15fe91bb7
2023-12-01 10:08:26,163 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:08:26,163 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:08:26,163 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:08:26,277 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:08:27,056 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:08:27,057 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/112fbcd21f9ebb245ce53b5daf4330e91d2d3d03.ta... for package 7eb4f6b582973401e2ddb7d44c33c347ef2fdaee
2023-12-01 10:08:27,091 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:08:27,092 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:08:27,092 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:08:27,141 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:08:29,910 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:08:29,913 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/42ccdca42885a5c16e5d0d1d7a4ff1f3a078899c.ta... for package 620add78c887bb1d1755397b98a1f0a94e886cb8
2023-12-01 10:08:29,948 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:08:29,948 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:08:29,948 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:08:30,017 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:08:31,418 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:08:31,419 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/94d8d341fe1afa10c84ad2b019fcacbe2c684ee6.ta... for package 620add78c887bb1d1755397b98a1f0a94e886cb8
2023-12-01 10:08:31,452 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:08:31,452 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:08:31,452 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:08:31,576 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:08:31,697 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:08:31,698 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/a4fe5857fdd2d4fe08dad2607303e6098a9cf387.ta... for package 2972d451293a075a2be62782f760dbff1547ae39
2023-12-01 10:08:31,725 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:08:31,725 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:08:31,725 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:08:31,981 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:08:31,985 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:08:31,985 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2b1d7a072d6eecf8879c2c262ec412b5c92de537.ta... for package 5a8a326a0bd0537927a92e8c634d574f1796d018
2023-12-01 10:08:32,011 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:08:32,011 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:08:32,012 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:08:32,130 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:08:35,329 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:08:35,332 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/8f3ad575294a47a65f1df819633ea67b182b2395.ta... for package 5a8a326a0bd0537927a92e8c634d574f1796d018
2023-12-01 10:08:35,359 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:08:35,360 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:08:35,360 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:08:35,423 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a
2023-12-01 10:08:36,772 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:09:13,850 - MainProcess(10172) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:09:28,890 - MainProcess(10172) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:10:22,165 - MainProcess(10172) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2023-12-01 10:10:22,171 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for fd3bc24fb0918545b269ae8da321e8d894c63aa7
2023-12-01 10:10:22,913 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 8b74479e7a54644b1f416d099776ef32bc2c34a1
2023-12-01 10:10:22,936 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 1a770a48d6a9cf17b653ae43d2bc455e8ba997eb
2023-12-01 10:10:22,936 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 31e0f47eabdd436bb829e0c65acf67ba(CREATE_PACKAGE_LINK)
2023-12-01 10:10:22,936 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package 1a770a48d6a9cf17b653ae43d2bc455e8ba997eb
2023-12-01 10:10:22,936 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 1a770a48d6a9cf17b653ae43d2bc455e8ba997eb
2023-12-01 10:10:22,971 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for cd398d360d746179da04a19fe608256034f75a64
2023-12-01 10:10:22,994 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for fb4c55ed2663d9a3f2eb28da6f60792b22a35639
2023-12-01 10:10:23,021 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 7cdfef548c5a41c52596927fcd47bc6f32bb9090
2023-12-01 10:10:23,042 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 08eac89f9fcad63010170837e2011dcd49d8230c
2023-12-01 10:10:23,064 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package c3a19ec53e408415a798386917886e0d2252e3ea
2023-12-01 10:10:23,064 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 31e0f47eabdd436bb829e0c65acf67ba(CREATE_PACKAGE_LINK)
2023-12-01 10:10:23,064 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action b32513729518446bbd4984e704827353(WRITE_GA_APPNAME)
2023-12-01 10:10:23,064 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Writing analytics session information to \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\streamingsession.json
2023-12-01 10:10:23,070 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package c3a19ec53e408415a798386917886e0d2252e3ea
2023-12-01 10:10:23,070 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for c3a19ec53e408415a798386917886e0d2252e3ea
2023-12-01 10:10:23,106 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 99ebf4ed6b3214119eeabeba58ac2f4656c3749e
2023-12-01 10:10:23,149 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for a567df632148f3e6831d18aca5c1efa8e9428a51
2023-12-01 10:10:23,175 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform predeploy tasks for package 3c95a5a1cb0e50a6e0b0e66ce4f1726cad890f0e
2023-12-01 10:10:23,175 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action a9cdc10b1ed64039b7dfd3bf8a0dcd5e(REMOVE_WININSTALLER_PRODUCT)
2023-12-01 10:10:23,306 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - WARNING :: Failed to remove windows installer product {CD2A85EC-C80D-4CAC-01C1-FCCDE4A651C8}. Msiexec returns 1605
2023-12-01 10:10:23,369 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - WARNING :: Failed to remove windows installer product {0188C9F4-CCDE-41E9-0150-6B1CFC6AC596}. Msiexec returns 1605
2023-12-01 10:10:23,369 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform predeploy tasks for package 3c95a5a1cb0e50a6e0b0e66ce4f1726cad890f0e
2023-12-01 10:10:23,370 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 3c95a5a1cb0e50a6e0b0e66ce4f1726cad890f0e
2023-12-01 10:10:23,453 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 95190f27fd4c9397eb899e5e2d68d9588d8b6b5b
2023-12-01 10:10:23,477 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 7afa45cadee95b425e4f4e0e42bfa5c3db823d9e
2023-12-01 10:10:23,501 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for c962179509c8630aed96b173eee01c1e11137184
2023-12-01 10:10:23,642 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 831018f04309093474438aa0acbaf990290f6cae
2023-12-01 10:10:23,665 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for b52270c742f3cc4d7ecc2f28e590aeab65411055
2023-12-01 10:10:23,702 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 1e23f39fce7bce012c7896905e9812b1fd308f6f
2023-12-01 10:10:23,729 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for b3c4465887ba56d69af092a443b467e15fe91bb7
2023-12-01 10:10:23,753 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 7eb4f6b582973401e2ddb7d44c33c347ef2fdaee
2023-12-01 10:10:23,777 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 620add78c887bb1d1755397b98a1f0a94e886cb8
2023-12-01 10:10:23,811 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 2972d451293a075a2be62782f760dbff1547ae39
2023-12-01 10:10:23,840 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 5a8a326a0bd0537927a92e8c634d574f1796d018
2023-12-01 10:10:23,840 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action e10f096356f7470ea58e13af02d1ba7c(UPDATE_PINNABLE_LAUNCHER)
2023-12-01 10:10:23,843 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action e11b50c4e45d49c68aa944c2e476a76f(Unknown) was not in registry
2023-12-01 10:10:23,843 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action b32513729518446bbd4984e704827353(WRITE_GA_APPNAME)
2023-12-01 10:10:23,844 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Writing analytics session information to \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\streamingsession.json
2023-12-01 10:10:23,853 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 7df3ec3a7e8d40ada66494b9dc32dc4e(ACTIVATE_CONFIG)
2023-12-01 10:10:23,865 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\Applications\Fusion\Fusion360App\ApplicationOptions.production.xml as \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\Fusion 360.server.config
2023-12-01 10:10:23,865 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2023-12-01 10:10:23,880 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\Applications\Fusion\Fusion360App\AdpSDKGlobal.production.config as \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\AdpSDKGlobal.config
2023-12-01 10:10:23,880 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2023-12-01 10:10:23,895 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\Applications\Fusion\Fusion360App\adpdesktopsdk.production.env as \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\adpdesktopsdk.env
2023-12-01 10:10:23,895 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2023-12-01 10:10:23,898 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 8df63efc00a94e9aa262d921a044c83a(PROCESS_TEMPLATE)
2023-12-01 10:10:23,899 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 9a6f9239365141149849b3081dc3fd7c(WRITE_STREAMER_OPTIONS)
2023-12-01 10:10:23,906 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value '0' to option 'GlobalInstall'
2023-12-01 10:10:23,906 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Remove option 'DevBuild'
2023-12-01 10:10:23,935 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:10:23,935 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:10:23,935 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:10:24,017 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: The ETag of url https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f... is 2084a67ee2476d66ef0b9e1ff8e391d0:1701379248.095092
2023-12-01 10:10:24,017 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...' to option 'StreamerRootUrl'
2023-12-01 10:10:24,017 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value '2084a67ee2476d66ef0b9e1ff8e391d0:1701379248.095092' to option 'ETag'
2023-12-01 10:10:24,017 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'production' to option 'InstallStream'
2023-12-01 10:10:24,018 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 1341bb4b8566410e9c7c8aef52bcb222(FILE_ASSOCIATIONS)
2023-12-01 10:10:24,035 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2023-12-01 10:10:24,036 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 4afd20f9b05b4349869fb10841d11444(DELIVER_ICON)
2023-12-01 10:10:24,036 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Deliver the icon of Fusion360.exe to the same folder as the Pinnable launcher.
2023-12-01 10:10:24,041 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2023-12-01 10:10:24,043 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2023-12-01 10:10:24,046 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2023-12-01 10:10:24,048 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2023-12-01 10:10:24,051 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2023-12-01 10:10:24,054 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2023-12-01 10:10:24,057 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action abd8ee230bcc49f9a56035b8eefedeed(REGISTER_UNINSTALL) was not in registry
2023-12-01 10:10:24,057 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 5ca4357a038540d58fb2092e8a9329a9(REGISTER_SAFE_MODE)
2023-12-01 10:10:25,128 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Streamer folder "C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\streamer\20231122000000" is found
2023-12-01 10:10:25,128 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Find the latest streamer executable "C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\streamer\20231122000000\streamer.exe"
2023-12-01 10:10:25,128 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Create shortcut file: C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\streamer\streamer.bat
2023-12-01 10:10:25,131 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Creating safe mode registry key "Software\Microsoft\Windows\CurrentVersion\Uninstall\73e72ada57b7480280f7a6f4a289729f"
2023-12-01 10:10:25,131 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion 360
2023-12-01 10:10:25,131 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2023-12-01 10:10:25,131 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion 360
2023-12-01 10:10:25,156 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2023-12-01 10:10:25,156 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2023-12-01 10:10:25,157 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 3af6a9fa26704d868bb90e12b3aed9be(EXTERNAL_INSTALLS)
2023-12-01 10:10:25,164 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2023-12-01 10:10:25,165 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 0b9a4c1251914f7facc25616ea0f9de3(CREATE_LAUNCH_ITEMS)
2023-12-01 10:10:25,173 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2023-12-01 10:10:25,174 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\FusionLauncher.exe is launchable. Creating a shortcut
2023-12-01 10:10:25,180 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion 360
2023-12-01 10:10:25,180 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2023-12-01 10:10:25,180 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion 360
2023-12-01 10:10:25,180 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2023-12-01 10:10:25,180 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2023-12-01 10:10:25,250 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion 360
2023-12-01 10:10:25,250 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2023-12-01 10:10:25,250 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion 360
2023-12-01 10:10:25,250 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2023-12-01 10:10:25,250 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2023-12-01 10:10:25,259 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Refresh icons for upgrade or live update on Win10 and above
2023-12-01 10:10:25,326 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 2c5d70c64a6a46008630fb0201c90351(WRITE_LAUNCHER_INI)
2023-12-01 10:10:25,332 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2023-12-01 10:10:25,338 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Cmd value is: ""C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\Fusion360.exe""
2023-12-01 10:10:25,339 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 14fd4E53b5d3476bb1C47d1fac493a50(AUTO_LAUNCH_ITEMS)
2023-12-01 10:10:25,345 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2023-12-01 10:10:25,346 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\FusionLauncher.exe is an autolaunch target
2023-12-01 10:10:25,346 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - WARNING :: Run default launch path failed. Try to run: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\FusionLauncher.exe
2023-12-01 10:10:25,346 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Attempting to launch: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\FusionLauncher.exe
2023-12-01 10:10:25,393 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\FusionLauncher.exe was launched
2023-12-01 10:10:25,393 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package 5a8a326a0bd0537927a92e8c634d574f1796d018
2023-12-01 10:10:25,393 - MainProcess(10172) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 5a8a326a0bd0537927a92e8c634d574f1796d018
2023-12-01 10:10:25,434 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The final progress is 1.0
2023-12-01 10:10:25,434 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Before perform the actions at the very end
2023-12-01 10:10:25,437 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/8448384f7771a48f527d0845e10c53c508347ee4.js... Complete in 0.088762522 seconds. (1701425087.7024548 1701425087.7912173)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/f47e23cb0dd0e8c3da8112223dab0de68894e6fb.js... Complete in 0.087765932 seconds. (1701425087.7922149 1701425087.8799808)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/f9d72584a7ccd644d61a1070fa8d631a25baa508.js... Complete in 0.1872201 seconds. (1701425087.8809795 1701425088.0681996)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/f1299b03727981443b84f9cb8842a2a50499a632.js... Complete in 0.20818949 seconds. (1701425088.0691712 1701425088.2773607)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/eb09053acccba626ac5debcebe7c4d34c82e7d05.js... Complete in 0.74121952 seconds. (1701425088.2923295 1701425089.033549)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/18180e76f6d8de6e431e982f0aab427a865e140c.js... Complete in 0.12067771 seconds. (1701425089.033549 1701425089.1542268)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/f9b89be5c7b7977b3281b839507b10025b1f0cc6.js... Complete in 0.20702171 seconds. (1701425089.1542268 1701425089.3612485)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/c0c60505751edf3ce14cddea85fc502b6248f688.js... Complete in 0.20908761 seconds. (1701425089.3612485 1701425089.570336)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/83a0e411d5e359dc273d94ed2e06ed55a1c502f6.js... Complete in 0.20476103 seconds. (1701425089.570336 1701425089.7750971)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/c975f886560950304f11ff1b6e0e573db6edd66d.js... Complete in 0.64801002 seconds. (1701425089.7750971 1701425090.4231071)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/429197af20b934df594c14b53975255b09bab97e.js... Complete in 0.15558362 seconds. (1701425090.4231071 1701425090.5786908)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/22f0ec0d8e16724c93eeb28814589c2b373d4a83.js... Complete in 0.52316904 seconds. (1701425090.5786908 1701425091.1018598)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/b3210048ef2054a5a32f15e9e7912f1f0c2d6545.js... Complete in 0.74792576 seconds. (1701425091.1018598 1701425091.8497856)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/9587cd629d084fdf205e6bf9c170c7125f7fe33d.js... Complete in 0.20351338 seconds. (1701425091.8497856 1701425092.053299)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/f27e8edebdda4d8a67b3a53667fb4912f4a9162e.js... Complete in 0.17992735 seconds. (1701425092.053299 1701425092.2332263)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/19090bf5efc7b82faffaaf993de69ffb3a4dd8d8.js... Complete in 0.18051648 seconds. (1701425092.2332263 1701425092.4137428)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/e72eac6166edafdc5bc7bc96ad11cec07ebfca14.js... Complete in 0.17951989 seconds. (1701425092.4137428 1701425092.5932627)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/503953f23ee2b7ea98d95ad29510f775079ca37e.js... Complete in 0.11269855 seconds. (1701425092.5932627 1701425092.7059612)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/bdf5f828404c59af756de01e99b6f6ffb3d4da3d.js... Complete in 0.46874642 seconds. (1701425092.7069597 1701425093.1757061)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/ccb9b4ffe027b5fa0623f44e0f8a86fbf8a0a0d3.js... Complete in 0.10671425 seconds. (1701425093.1767027 1701425093.283417)
2023-12-01 10:10:25,438 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/e911d548da767ec1dc351b5990c9a556e0fddd26.js... Complete in 0.092752695 seconds. (1701425093.283417 1701425093.3761697)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/3e5e194a6b803bda06f96b96e4238a38007abd47.js... Complete in 0.78404665 seconds. (1701425093.3761697 1701425094.1602163)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/cbb3675fafbbd97c576525bd628450b411a2b1ef.js... Complete in 0.19345808 seconds. (1701425094.1602163 1701425094.3536744)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/66b1a9e045ad7faae5745672857dd81cd9513203.js... Complete in 0.1077137 seconds. (1701425094.3546717 1701425094.4623854)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/410fb71474b87a60adda9476f2369385e7d539d8.js... Complete in 0.21342754 seconds. (1701425094.4623854 1701425094.675813)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/ef71691fc03b9bfe393a787d7238c4a3f13ad5cb.js... Complete in 0.18353367 seconds. (1701425094.675813 1701425094.8593466)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/ef15d74705aae519a4bb55ab33647b54442f13f1.js... Complete in 0.82868743 seconds. (1701425094.8603594 1701425095.6890469)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/e5b60f15cceaf30083d05c3dea795a799e5665ea.js... Complete in 0.66016555 seconds. (1701425095.6900194 1701425096.350185)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/3994ef5c397cdfe37541503e333a4a390a5eff8f.js... Complete in 0.14590812 seconds. (1701425096.3511832 1701425096.4970913)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/4e77ab2ae8dd4a3f1773f5516e96bd2e1e806dcd.js... Complete in 0.082777977 seconds. (1701425096.4970913 1701425096.5798693)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/bd27dfce780626fe4ceccb4dd4ca267597ee5151.js... Complete in 0.17969251 seconds. (1701425096.5798693 1701425096.7595618)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/8fc098769a2b8a0204dff52aac01c9258b04d683.js... Complete in 0.80126119 seconds. (1701425096.7595618 1701425097.560823)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/635d3cd0959f516509c05e48bca8b4552ff2b2dc.js... Complete in 0.21019125 seconds. (1701425097.560823 1701425097.7710142)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/67b62ded3169893ad39c8987f9e04737cec50bf9.js... Complete in 0.13264489 seconds. (1701425097.7710142 1701425097.903659)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/eedfe3251233c571f70195d73e6673f5486f32e4.js... Complete in 0.11770988 seconds. (1701425097.903659 1701425098.021369)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/dd54cc9d2b41180ea3f81101cec060e0fbcafd9f.js... Complete in 0.69355392 seconds. (1701425098.021369 1701425098.714923)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/73c592c74ab19b6ca3e301a07569f7497b02d380.js... Complete in 0.21740079 seconds. (1701425098.714923 1701425098.9323237)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/cb3c524a531e26b56e9873c24cc57bb56604acc8.js... Complete in 0.19348383 seconds. (1701425098.9323237 1701425099.1258075)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/feb2db168757a03e3c6ae3651ea5126d8febebbc.js... Complete in 0.17843938 seconds. (1701425099.1258075 1701425099.304247)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/5c567f46b36668461f291d0b730651ce5bfc782f.js... Complete in 0.19920278 seconds. (1701425099.304247 1701425099.5034497)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/7b950498fc3ac93faf7f46bd95de01a4a8be487b.js... Complete in 0.18145657 seconds. (1701425099.5034497 1701425099.6849062)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/526693d9f6b3b90b9c32c1dfc4807f3efc652e26.js... Complete in 0.19647479 seconds. (1701425099.68588 1701425099.8823547)
2023-12-01 10:10:25,439 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/fd3bc24fb0918545b269ae8da321e8d894c63aa7.js... Complete in 0.17253804 seconds. (1701425099.8823547 1701425100.0548928)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/8b74479e7a54644b1f416d099776ef32bc2c34a1.js... Complete in 0.17431498 seconds. (1701425100.0548928 1701425100.2292078)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/1a770a48d6a9cf17b653ae43d2bc455e8ba997eb.js... Complete in 0.17552686 seconds. (1701425100.230207 1701425100.4057338)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/cd398d360d746179da04a19fe608256034f75a64.js... Complete in 0.15857649 seconds. (1701425100.406731 1701425100.5653074)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/fb4c55ed2663d9a3f2eb28da6f60792b22a35639.js... Complete in 0.10172629 seconds. (1701425100.5653074 1701425100.6670337)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/7cdfef548c5a41c52596927fcd47bc6f32bb9090.js... Complete in 1.1402023 seconds. (1701425100.6670337 1701425101.807236)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/08eac89f9fcad63010170837e2011dcd49d8230c.js... Complete in 0.69235778 seconds. (1701425101.807236 1701425102.4995937)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/c3a19ec53e408415a798386917886e0d2252e3ea.js... Complete in 0.46840906 seconds. (1701425102.4995937 1701425102.9680028)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/99ebf4ed6b3214119eeabeba58ac2f4656c3749e.js... Complete in 0.43573856 seconds. (1701425102.9680028 1701425103.4037414)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/a567df632148f3e6831d18aca5c1efa8e9428a51.js... Complete in 0.86104727 seconds. (1701425103.4037414 1701425104.2647886)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/3c95a5a1cb0e50a6e0b0e66ce4f1726cad890f0e.js... Complete in 0.4303484 seconds. (1701425104.2647886 1701425104.695137)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/95190f27fd4c9397eb899e5e2d68d9588d8b6b5b.js... Complete in 1.3293965 seconds. (1701425104.695137 1701425106.0245335)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/7afa45cadee95b425e4f4e0e42bfa5c3db823d9e.js... Complete in 0.39734292 seconds. (1701425106.0245335 1701425106.4218764)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/c962179509c8630aed96b173eee01c1e11137184.js... Complete in 0.98059654 seconds. (1701425106.4218764 1701425107.402473)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/831018f04309093474438aa0acbaf990290f6cae.js... Complete in 0.625278 seconds. (1701425107.402473 1701425108.027751)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/b52270c742f3cc4d7ecc2f28e590aeab65411055.js... Complete in 0.19422889 seconds. (1701425108.027751 1701425108.2219799)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/1e23f39fce7bce012c7896905e9812b1fd308f6f.js... Complete in 0.43333507 seconds. (1701425108.2219799 1701425108.655315)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/b3c4465887ba56d69af092a443b467e15fe91bb7.js... Complete in 0.17755938 seconds. (1701425108.6563203 1701425108.8338797)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/7eb4f6b582973401e2ddb7d44c33c347ef2fdaee.js... Complete in 0.48224616 seconds. (1701425108.8338797 1701425109.3161259)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/620add78c887bb1d1755397b98a1f0a94e886cb8.js... Complete in 0.78377008 seconds. (1701425109.3161259 1701425110.099896)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/2972d451293a075a2be62782f760dbff1547ae39.js... Complete in 0.71709824 seconds. (1701425110.099896 1701425110.8169942)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pull Manifest : https://dl.appstreaming.autodesk.com/production/packages/5a8a326a0bd0537927a92e8c634d574f1796d018.js... Complete in 1.1910877 seconds. (1701425110.8169942 1701425112.008082)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: meshmixer_win , Size 5067888 bytes , complete in 4.3140266 seconds. (1701425087.7912173 1701425092.105244)
2023-12-01 10:10:25,440 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: atf_win , Size 18576624 bytes , complete in 23.326971 seconds. (1701425087.8799808 1701425111.2069514)
2023-12-01 10:10:25,441 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: clientframework_win , Size 688236 bytes , complete in 0.65818691 seconds. (1701425088.0681996 1701425088.7263865)
2023-12-01 10:10:25,441 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: LibrariesPlatform_win , Size 220344 bytes , complete in 0.58149886 seconds. (1701425088.2773607 1701425088.8588595)
2023-12-01 10:10:25,441 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: LibraryClientPlatform_win , Size 6126920 bytes , complete in 4.4313817 seconds. (1701425089.033549 1701425093.4649308)
2023-12-01 10:10:25,441 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: gelib_win , Size 420852 bytes , complete in 1.1811171 seconds. (1701425089.1542268 1701425090.3353438)
2023-12-01 10:10:25,441 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: cer_win , Size 1999140 bytes , complete in 2.3269703 seconds. (1701425089.3612485 1701425091.6882188)
2023-12-01 10:10:25,441 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: install_ms , Size 9316100 bytes , complete in 10.971034 seconds. (1701425089.570336 1701425100.54137)
2023-12-01 10:10:25,441 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: libcurl_win , Size 215856 bytes , complete in 2.7284064 seconds. (1701425089.7750971 1701425092.5035036)
2023-12-01 10:10:25,441 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: liboss_win , Size 1222504 bytes , complete in 2.8264008 seconds. (1701425090.4231071 1701425093.249508)
2023-12-01 10:10:25,441 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: lrp_win , Size 2064728 bytes , complete in 3.9574955 seconds. (1701425090.5786908 1701425094.5361862)
2023-12-01 10:10:25,441 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: raas_win , Size 555936 bytes , complete in 3.2318692 seconds. (1701425091.1018598 1701425094.333729)
2023-12-01 10:10:25,441 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: adp_win , Size 4333836 bytes , complete in 4.6942048 seconds. (1701425091.8497856 1701425096.5439904)
2023-12-01 10:10:25,441 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: synhub_win , Size 1639332 bytes , complete in 4.259984 seconds. (1701425092.053299 1701425096.313283)
2023-12-01 10:10:25,441 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: upi_win , Size 119196 bytes , complete in 4.2369368 seconds. (1701425092.2332263 1701425096.470163)
2023-12-01 10:10:25,441 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: v8_win , Size 6457816 bytes , complete in 8.5475056 seconds. (1701425092.4137428 1701425100.9612484)
2023-12-01 10:10:25,441 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: vcs_win , Size 1313860 bytes , complete in 5.255543 seconds. (1701425092.5932627 1701425097.8488057)
2023-12-01 10:10:25,441 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: xerces_win , Size 704292 bytes , complete in 5.7138417 seconds. (1701425092.7059612 1701425098.419803)
2023-12-01 10:10:25,442 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: browsercomponent_win , Size 47121280 bytes , complete in 49.199541 seconds. (1701425093.1757061 1701425142.375247)
2023-12-01 10:10:25,442 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: a360_win , Size 666108 bytes , complete in 7.8214457 seconds. (1701425093.283417 1701425101.1048627)
2023-12-01 10:10:25,442 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: airmax_win , Size 49421696 bytes , complete in 52.851065 seconds. (1701425093.3761697 1701425146.2272344)
2023-12-01 10:10:25,442 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: asm_win , Size 23237412 bytes , complete in 24.722137 seconds. (1701425094.1602163 1701425118.882353)
2023-12-01 10:10:25,442 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: qt_win , Size 66585056 bytes , complete in 82.51478 seconds. (1701425094.3536744 1701425176.8684547)
2023-12-01 10:10:25,442 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: python_win , Size 19260588 bytes , complete in 39.154457 seconds. (1701425094.4623854 1701425133.6168427)
2023-12-01 10:10:25,442 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: htmltopdf_win , Size 11677116 bytes , complete in 45.155923 seconds. (1701425094.675813 1701425139.8317358)
2023-12-01 10:10:25,442 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: neuhtmltopdf_win , Size 23432 bytes , complete in 45.077083 seconds. (1701425094.8593466 1701425139.93643)
2023-12-01 10:10:25,442 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: nodejs_win , Size 15423688 bytes , complete in 55.190109 seconds. (1701425095.6890469 1701425150.8791559)
2023-12-01 10:10:25,442 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: ldcsdk_win , Size 218692 bytes , complete in 46.327097 seconds. (1701425096.350185 1701425142.6772823)
2023-12-01 10:10:25,442 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: api_win , Size 1303672 bytes , complete in 48.944679 seconds. (1701425096.4970913 1701425145.4417706)
2023-12-01 10:10:25,442 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: 7zip_win , Size 528948 bytes , complete in 49.437811 seconds. (1701425096.5798693 1701425146.0176806)
2023-12-01 10:10:25,442 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: openssl_win , Size 1263536 bytes , complete in 50.266337 seconds. (1701425096.7595618 1701425147.0258992)
2023-12-01 10:10:25,443 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: idsdk_win , Size 163607052 bytes , complete in 191.90471 seconds. (1701425097.560823 1701425289.4655282)
2023-12-01 10:10:25,443 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: brepunwrap_win , Size 401712 bytes , complete in 49.744799 seconds. (1701425097.7710142 1701425147.5158129)
2023-12-01 10:10:25,443 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: weaveqml_win , Size 1103628 bytes , complete in 50.60703 seconds. (1701425097.903659 1701425148.510689)
2023-12-01 10:10:25,443 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: fusionqml_win , Size 47360 bytes , complete in 50.61654 seconds. (1701425098.021369 1701425148.6379094)
2023-12-01 10:10:25,443 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: neutron_win , Size 155122612 bytes , complete in 198.56285 seconds. (1701425098.714923 1701425297.2777774)
2023-12-01 10:10:25,443 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: 73c592c74ab19b6ca3e301a07569f7497b02d380 , Size 41609188 bytes , complete in 89.255419 seconds. (1701425098.9323237 1701425188.1877432)
2023-12-01 10:10:25,443 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: smtk_win , Size 239252 bytes , complete in 78.065783 seconds. (1701425099.1258075 1701425177.19159)
2023-12-01 10:10:25,443 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: modeling_win , Size 57256856 bytes , complete in 134.46482 seconds. (1701425099.304247 1701425233.769068)
2023-12-01 10:10:25,443 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: tsplines_win , Size 670304 bytes , complete in 89.39826 seconds. (1701425099.5034497 1701425188.9017098)
2023-12-01 10:10:25,443 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: idealizations_win , Size 17742220 bytes , complete in 109.50039 seconds. (1701425099.6849062 1701425209.1853)
2023-12-01 10:10:25,443 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: fabrication_win , Size 16034484 bytes , complete in 118.40862 seconds. (1701425099.8823547 1701425218.2909763)
2023-12-01 10:10:25,443 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: cam_win , Size 239835108 bytes , complete in 322.11673 seconds. (1701425100.0548928 1701425422.1716275)
2023-12-01 10:10:25,443 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: opencv_win , Size 4601744 bytes , complete in 136.94498 seconds. (1701425100.2292078 1701425237.1741908)
2023-12-01 10:10:25,443 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: animation_win , Size 1863828 bytes , complete in 138.85503 seconds. (1701425100.4057338 1701425239.2607617)
2023-12-01 10:10:25,443 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: FusionLauncher-launcher-packaging-script , Size 94004 bytes , complete in 139.02757 seconds. (1701425100.5653074 1701425239.592874)
2023-12-01 10:10:25,443 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: feacs_win , Size 9977368 bytes , complete in 143.90119 seconds. (1701425100.6670337 1701425244.5682235)
2023-12-01 10:10:25,444 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: vtk_win , Size 2694460 bytes , complete in 144.38083 seconds. (1701425101.807236 1701425246.188064)
2023-12-01 10:10:25,444 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: adsksimpkgsolvershared_win , Size 1410256 bytes , complete in 144.78155 seconds. (1701425102.4995937 1701425247.281145)
2023-12-01 10:10:25,444 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: simulus_win , Size 19641996 bytes , complete in 160.82006 seconds. (1701425102.9680028 1701425263.7880652)
2023-12-01 10:10:25,444 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: fusiondocstreamer_win , Size 170861196 bytes , complete in 265.48898 seconds. (1701425103.4037414 1701425368.892718)
2023-12-01 10:10:25,444 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: accoreview_win , Size 115188 bytes , complete in 185.37131 seconds. (1701425104.2647886 1701425289.6360955)
2023-12-01 10:10:25,444 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: drawing_win , Size 7661836 bytes , complete in 194.69214 seconds. (1701425104.695137 1701425299.38728)
2023-12-01 10:10:25,444 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: ntest_serveronly_win , Size 175184 bytes , complete in 192.36119 seconds. (1701425106.0245335 1701425298.3857229)
2023-12-01 10:10:25,444 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: electronicsqml_win , Size 114776 bytes , complete in 192.25108 seconds. (1701425106.4218764 1701425298.672954)
2023-12-01 10:10:25,444 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: electron_win , Size 68746400 bytes , complete in 246.44986 seconds. (1701425107.402473 1701425353.852337)
2023-12-01 10:10:25,444 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: reform_win , Size 5295332 bytes , complete in 195.34883 seconds. (1701425108.027751 1701425303.3765771)
2023-12-01 10:10:25,444 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: paramesh_win , Size 2184112 bytes , complete in 197.37979 seconds. (1701425108.2219799 1701425305.6017725)
2023-12-01 10:10:25,444 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: lib3mf_win , Size 460664 bytes , complete in 197.47872 seconds. (1701425108.655315 1701425306.134032)
2023-12-01 10:10:25,444 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: avk_win , Size 1273796 bytes , complete in 198.22362 seconds. (1701425108.8338797 1701425307.0574949)
2023-12-01 10:10:25,444 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: krypton_win , Size 3689700 bytes , complete in 200.59693 seconds. (1701425109.3161259 1701425309.9130552)
2023-12-01 10:10:25,444 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: volumetricfield_win , Size 1079840 bytes , complete in 201.5983 seconds. (1701425110.099896 1701425311.698192)
2023-12-01 10:10:25,444 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: qtwinmigrate_win , Size 24524 bytes , complete in 201.16858 seconds. (1701425110.8169942 1701425311.98557)
2023-12-01 10:10:25,444 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package: fusion_win , Size 7790940 bytes , complete in 204.76649 seconds. (1701425112.008082 1701425316.7745726)
2023-12-01 10:10:25,444 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Application 73e72ada57b7480280f7a6f4a289729f installed.
2023-12-01 10:10:25,857 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Updating Registry Stream Info
2023-12-01 10:10:25,857 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Update streamer info in Registry, tag: production, root: https://dl.appstreaming.autodesk.com/production/
2023-12-01 10:10:25,862 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Update streamer last install to: 2023-12-01 10:10:25.862436
2023-12-01 10:10:25,868 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app complete Deploy to 2.0.17954 for app 73e72ada57b7480280f7a6f4a289729f
2023-12-01 10:10:25,880 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Process Complete in 338.29761 seconds
2023-12-01 10:10:25,880 - MainProcess(10172) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.analytics - INFO :: Sending analytics for command "Deploy.ProcessComplete" args: ['73e72ada57b7480280f7a6f4a289729f', '2.0.17954']
2023-12-01 10:10:27,358 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2023-12-01 10:10:27,365 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2023-12-01 10:10:27,366 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2023-12-01 10:10:27,366 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 10:10:27,366 - MainProcess(10172) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000020E31128610> #
2023-12-01 10:48:15,586 - MainProcess(16480) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\alexb\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2023-12-01 10:48:15,586 - MainProcess(16480) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2023-12-01 10:48:15,586 - MainProcess(16480) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 10:48:15,586 - MainProcess(16480) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001F53BA4C910> #
2023-12-01 10:48:15,587 - MainProcess(16480) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 10:48:15,587 - MainProcess(16480) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-01 10:48:15,587 - MainProcess(16480) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\streamer\20231122000000\resources\buildinfo.json
2023-12-01 10:48:15,587 - MainProcess(16480) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2023-12-01 10:48:15,587 - MainProcess(16480) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20231122000000
2023-12-01 10:48:15,587 - MainProcess(16480) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_GB
2023-12-01 10:48:15,588 - MainProcess(16480) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\streamer\20231122000000\resources
2023-12-01 10:48:15,589 - MainProcess(16480) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\streamer\20231122000000\certs.pem
2023-12-01 10:48:15,589 - MainProcess(16480) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2023-12-01 10:48:15,590 - MainProcess(16480) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2023-12-01 10:48:15,590 - MainProcess(16480) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2023-12-01 10:48:15,590 - MainProcess(16480) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function uninstall_process at 0x000001F53BA2BBA0>, operation=<function multiple_operate at 0x000001F53B10FC40>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection=None, update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=True, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=True, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2023-12-01 10:48:15,590 - MainProcess(16480) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2023-12-01 10:48:15,590 - MainProcess(16480) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2023-12-01 10:48:15,591 - MainProcess(16480) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2023-12-01 10:48:15,591 - MainProcess(16480) - MessageThread - adsk.dls.streamer.ui.headless - INFO :: Begin sending message in headless mode.
2023-12-01 10:48:15,591 - MainProcess(16480) - MainThread - adsk.dls.streamer.process.process - INFO :: Start to run process: Cleanup
2023-12-01 10:48:15,658 - MainProcess(16480) - MainThread - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2023-12-01 10:48:16,109 - MainProcess(16480) - MainThread - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2023-12-01 10:48:16,110 - MainProcess(16480) - MainThread - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2023-12-01 10:48:16,110 - MainProcess(16480) - MainThread - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2023-12-01 10:48:16,110 - MainProcess(16480) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2023-12-01 10:48:16,110 - MainProcess(16480) - MainThread - adsk.dls.streamer.process.process - INFO :: The session id is f0187150-0ae7-486e-911c-bf4012e1167e
2023-12-01 10:48:16,111 - MainProcess(16480) - MainThread - adsk.dls.streamer.process.process - INFO :: Configure app begin Cleanup
2023-12-01 10:48:16,111 - MainProcess(16480) - MainThread - adsk.dls.streamer.process.uninstall_process - INFO :: Cleaning up old-version apps, ignoring any apps except for packages belonging to an in-progress app
2023-12-01 10:48:16,111 - MainProcess(16480) - MainThread - adsk.dls.streamer.process.uninstall_process - INFO :: Check app: 73e72ada57b7480280f7a6f4a289729f
2023-12-01 10:48:16,130 - MainProcess(16480) - MainThread - adsk.dls.streamer.process.process - INFO :: Configure app complete Cleanup
2023-12-01 10:48:16,130 - MainProcess(16480) - MainThread - adsk.dls.streamer.process.process - INFO :: Process Complete in 0.019949913 seconds
2023-12-01 10:48:17,591 - MainProcess(16480) - MainThread - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2023-12-01 10:48:17,596 - MainProcess(16480) - MainThread - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2023-12-01 10:48:17,597 - MainProcess(16480) - MainThread - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2023-12-01 10:48:17,597 - MainProcess(16480) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 10:48:17,597 - MainProcess(16480) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001F53BA4C910> #
2023-12-01 10:48:17,597 - MainProcess(16480) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-01 10:48:44,925 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\alexb\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2023-12-01 10:48:44,926 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2023-12-01 10:48:44,926 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 10:48:44,926 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000002B5DB7A6D50> #
2023-12-01 10:48:44,926 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-01 10:48:44,926 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\resources\buildinfo.json
2023-12-01 10:48:44,927 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2023-12-01 10:48:44,927 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20231122000000
2023-12-01 10:48:44,927 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_GB
2023-12-01 10:48:44,928 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\resources
2023-12-01 10:48:44,929 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer - INFO :: New logging level: 20
2023-12-01 10:48:44,930 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: Start to run process: Update
2023-12-01 10:48:45,015 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2023-12-01 10:48:45,463 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: Skipping pre-checks. Found environment variable SKIP_PRECHECK OR Admin install.
2023-12-01 10:48:45,465 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2023-12-01 10:48:45,466 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2023-12-01 10:48:45,466 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2023-12-01 10:48:45,512 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2023-12-01 10:48:45,512 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-01 10:48:45,512 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-01 10:48:45,540 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:48:45,540 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:48:45,540 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:48:45,540 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2023-12-01 10:48:45,540 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2023-12-01 10:48:45,560 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 104.82.197.165
2023-12-01 10:48:45,580 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2023-12-01 10:48:45,594 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: S_I: MTA0LjgyLjE5Ny4xNjU=
2023-12-01 10:48:45,594 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjY0
2023-12-01 10:48:45,594 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2023-12-01 10:48:45,595 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2023-12-01 10:48:45,646 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Update status: full
2023-12-01 10:48:45,646 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-01 10:48:45,646 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-01 10:48:45,672 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:48:45,672 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:48:45,672 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:48:45,736 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Update status: full
2023-12-01 10:48:45,736 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Searching the database for installed apps to update
2023-12-01 10:48:45,739 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Currently installed version for app 73e72ada57b7480280f7a6f4a289729f is 2.0.17954(20231130181907)
2023-12-01 10:48:45,739 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Try to fetch full update manifest file.
2023-12-01 10:48:45,739 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-01 10:48:45,739 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-01 10:48:45,779 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 10:48:45,779 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 10:48:45,779 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 10:48:45,829 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Update status: full
2023-12-01 10:48:45,830 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: App(73e72ada57b7480280f7a6f4a289729f) is already installed, skip updating.
2023-12-01 10:48:45,830 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: No apps need to install/live update.
2023-12-01 10:48:46,718 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2023-12-01 10:48:46,719 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2023-12-01 10:48:46,719 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2023-12-01 10:48:46,719 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 10:48:46,719 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000002B5DB7A6D50> #
2023-12-01 10:48:46,719 - MainProcess(18888) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-01 11:44:57,595 - MainProcess(4944) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\alexb\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2023-12-01 11:44:57,595 - MainProcess(4944) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2023-12-01 11:44:57,596 - MainProcess(4944) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 11:44:57,596 - MainProcess(4944) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000012C2F1F2750> #
2023-12-01 11:44:57,596 - MainProcess(4944) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-01 11:44:57,596 - MainProcess(4944) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\streamer\20231122000000\resources\buildinfo.json
2023-12-01 11:44:57,596 - MainProcess(4944) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2023-12-01 11:44:57,596 - MainProcess(4944) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20231122000000
2023-12-01 11:44:57,596 - MainProcess(4944) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_GB
2023-12-01 11:44:57,597 - MainProcess(4944) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\streamer\20231122000000\resources
2023-12-01 11:44:57,598 - MainProcess(4944) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\streamer\20231122000000\certs.pem
2023-12-01 11:44:57,598 - MainProcess(4944) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2023-12-01 11:44:57,599 - MainProcess(4944) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2023-12-01 11:44:57,599 - MainProcess(4944) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2023-12-01 11:44:57,599 - MainProcess(4944) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function uninstall_process at 0x0000012C2FBA7BA0>, operation=<function multiple_operate at 0x0000012C2F28FC40>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection=None, update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=True, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=True, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2023-12-01 11:44:57,599 - MainProcess(4944) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2023-12-01 11:44:57,600 - MainProcess(4944) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2023-12-01 11:44:57,600 - MainProcess(4944) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2023-12-01 11:44:57,600 - MainProcess(4944) - MessageThread - adsk.dls.streamer.ui.headless - INFO :: Begin sending message in headless mode.
2023-12-01 11:44:57,601 - MainProcess(4944) - MainThread - adsk.dls.streamer.process.process - INFO :: Start to run process: Cleanup
2023-12-01 11:44:57,674 - MainProcess(4944) - MainThread - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2023-12-01 11:44:58,117 - MainProcess(4944) - MainThread - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2023-12-01 11:44:58,118 - MainProcess(4944) - MainThread - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2023-12-01 11:44:58,118 - MainProcess(4944) - MainThread - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2023-12-01 11:44:58,119 - MainProcess(4944) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2023-12-01 11:44:58,119 - MainProcess(4944) - MainThread - adsk.dls.streamer.process.process - INFO :: The session id is 52937025-7ddc-4585-9b67-409a8c8bfafd
2023-12-01 11:44:58,119 - MainProcess(4944) - MainThread - adsk.dls.streamer.process.process - INFO :: Configure app begin Cleanup
2023-12-01 11:44:58,119 - MainProcess(4944) - MainThread - adsk.dls.streamer.process.uninstall_process - INFO :: Cleaning up old-version apps, ignoring any apps except for packages belonging to an in-progress app
2023-12-01 11:44:58,119 - MainProcess(4944) - MainThread - adsk.dls.streamer.process.uninstall_process - INFO :: Check app: 73e72ada57b7480280f7a6f4a289729f
2023-12-01 11:44:58,138 - MainProcess(4944) - MainThread - adsk.dls.streamer.process.process - INFO :: Configure app complete Cleanup
2023-12-01 11:44:58,138 - MainProcess(4944) - MainThread - adsk.dls.streamer.process.process - INFO :: Process Complete in 0.019950628 seconds
2023-12-01 11:44:59,588 - MainProcess(4944) - MainThread - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2023-12-01 11:44:59,594 - MainProcess(4944) - MainThread - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2023-12-01 11:44:59,594 - MainProcess(4944) - MainThread - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2023-12-01 11:44:59,594 - MainProcess(4944) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 11:44:59,594 - MainProcess(4944) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000012C2F1F2750> #
2023-12-01 11:44:59,594 - MainProcess(4944) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-01 11:47:22,516 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\alexb\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2023-12-01 11:47:22,517 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2023-12-01 11:47:22,517 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 11:47:22,517 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x00000195E1A254D0> #
2023-12-01 11:47:22,517 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-01 11:47:22,517 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\resources\buildinfo.json
2023-12-01 11:47:22,518 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2023-12-01 11:47:22,518 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20231122000000
2023-12-01 11:47:22,518 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_GB
2023-12-01 11:47:22,519 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\resources
2023-12-01 11:47:22,520 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer - INFO :: New logging level: 20
2023-12-01 11:47:22,520 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: Start to run process: Update
2023-12-01 11:47:22,587 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2023-12-01 11:47:23,061 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: Skipping pre-checks. Found environment variable SKIP_PRECHECK OR Admin install.
2023-12-01 11:47:23,064 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2023-12-01 11:47:23,064 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2023-12-01 11:47:23,065 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2023-12-01 11:47:23,134 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2023-12-01 11:47:23,134 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-01 11:47:23,134 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-01 11:47:23,174 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 11:47:23,174 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 11:47:23,175 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 11:47:23,175 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2023-12-01 11:47:23,175 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2023-12-01 11:47:23,190 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 104.103.158.73
2023-12-01 11:47:23,199 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2023-12-01 11:47:23,213 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: S_I: MTA0LjEwMy4xNTguNzM=
2023-12-01 11:47:23,213 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjY0
2023-12-01 11:47:23,214 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2023-12-01 11:47:23,214 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2023-12-01 11:47:23,267 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Update status: full
2023-12-01 11:47:23,267 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-01 11:47:23,267 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-01 11:47:23,294 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 11:47:23,294 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 11:47:23,294 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 11:47:23,337 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Update status: full
2023-12-01 11:47:23,337 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Searching the database for installed apps to update
2023-12-01 11:47:23,338 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Currently installed version for app 73e72ada57b7480280f7a6f4a289729f is 2.0.17954(20231130181907)
2023-12-01 11:47:23,338 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Try to fetch full update manifest file.
2023-12-01 11:47:23,338 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-01 11:47:23,338 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-01 11:47:23,362 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 11:47:23,362 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 11:47:23,362 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 11:47:23,414 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Update status: full
2023-12-01 11:47:23,414 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: App(73e72ada57b7480280f7a6f4a289729f) is already installed, skip updating.
2023-12-01 11:47:23,414 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: No apps need to install/live update.
2023-12-01 11:47:24,375 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2023-12-01 11:47:24,376 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2023-12-01 11:47:24,376 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2023-12-01 11:47:24,376 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 11:47:24,376 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x00000195E1A254D0> #
2023-12-01 11:47:24,376 - MainProcess(19092) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-01 11:49:20,682 - MainProcess(20204) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\alexb\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2023-12-01 11:49:20,683 - MainProcess(20204) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2023-12-01 11:49:20,683 - MainProcess(20204) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 11:49:20,683 - MainProcess(20204) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000018ACDA1A790> #
2023-12-01 11:49:20,683 - MainProcess(20204) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-01 11:49:20,683 - MainProcess(20204) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\streamer\20231122000000\resources\buildinfo.json
2023-12-01 11:49:20,683 - MainProcess(20204) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2023-12-01 11:49:20,684 - MainProcess(20204) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20231122000000
2023-12-01 11:49:20,684 - MainProcess(20204) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_GB
2023-12-01 11:49:20,684 - MainProcess(20204) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\streamer\20231122000000\resources
2023-12-01 11:49:20,687 - MainProcess(20204) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\streamer\20231122000000\certs.pem
2023-12-01 11:49:20,687 - MainProcess(20204) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2023-12-01 11:49:20,688 - MainProcess(20204) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2023-12-01 11:49:20,688 - MainProcess(20204) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2023-12-01 11:49:20,688 - MainProcess(20204) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function uninstall_process at 0x0000018ACDA67BA0>, operation=<function multiple_operate at 0x0000018ACD14FC40>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection=None, update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=True, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=True, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2023-12-01 11:49:20,688 - MainProcess(20204) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2023-12-01 11:49:20,688 - MainProcess(20204) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2023-12-01 11:49:20,688 - MainProcess(20204) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2023-12-01 11:49:20,689 - MainProcess(20204) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2023-12-01 11:49:20,689 - MainProcess(20204) - MessageThread - adsk.dls.streamer.ui.headless - INFO :: Begin sending message in headless mode.
2023-12-01 11:49:20,689 - MainProcess(20204) - MainThread - adsk.dls.streamer.process.process - INFO :: Start to run process: Cleanup
2023-12-01 11:49:20,755 - MainProcess(20204) - MainThread - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2023-12-01 11:49:21,161 - MainProcess(20204) - MainThread - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2023-12-01 11:49:21,161 - MainProcess(20204) - MainThread - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2023-12-01 11:49:21,162 - MainProcess(20204) - MainThread - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2023-12-01 11:49:21,162 - MainProcess(20204) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2023-12-01 11:49:21,162 - MainProcess(20204) - MainThread - adsk.dls.streamer.process.process - INFO :: The session id is 3bfd92fd-5406-40e0-9a43-77386edf2baa
2023-12-01 11:49:21,162 - MainProcess(20204) - MainThread - adsk.dls.streamer.process.process - INFO :: Configure app begin Cleanup
2023-12-01 11:49:21,163 - MainProcess(20204) - MainThread - adsk.dls.streamer.process.uninstall_process - INFO :: Cleaning up old-version apps, ignoring any apps except for packages belonging to an in-progress app
2023-12-01 11:49:21,163 - MainProcess(20204) - MainThread - adsk.dls.streamer.process.uninstall_process - INFO :: Check app: 73e72ada57b7480280f7a6f4a289729f
2023-12-01 11:49:21,182 - MainProcess(20204) - MainThread - adsk.dls.streamer.process.process - INFO :: Configure app complete Cleanup
2023-12-01 11:49:21,182 - MainProcess(20204) - MainThread - adsk.dls.streamer.process.process - INFO :: Process Complete in 0.019946575 seconds
2023-12-01 11:49:22,549 - MainProcess(20204) - MainThread - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2023-12-01 11:49:22,554 - MainProcess(20204) - MainThread - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2023-12-01 11:49:22,554 - MainProcess(20204) - MainThread - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2023-12-01 11:49:22,554 - MainProcess(20204) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 11:49:22,554 - MainProcess(20204) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000018ACDA1A790> #
2023-12-01 11:49:22,554 - MainProcess(20204) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-01 11:49:23,144 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\alexb\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2023-12-01 11:49:23,145 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2023-12-01 11:49:23,145 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 11:49:23,145 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000020AF76656D0> #
2023-12-01 11:49:23,145 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-01 11:49:23,145 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\resources\buildinfo.json
2023-12-01 11:49:23,145 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2023-12-01 11:49:23,145 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20231122000000
2023-12-01 11:49:23,146 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_GB
2023-12-01 11:49:23,146 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\resources
2023-12-01 11:49:23,147 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer - INFO :: New logging level: 20
2023-12-01 11:49:23,148 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: Start to run process: Update
2023-12-01 11:49:23,221 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2023-12-01 11:49:23,715 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: Skipping pre-checks. Found environment variable SKIP_PRECHECK OR Admin install.
2023-12-01 11:49:23,717 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2023-12-01 11:49:23,718 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2023-12-01 11:49:23,718 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2023-12-01 11:49:23,774 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2023-12-01 11:49:23,774 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-01 11:49:23,774 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-01 11:49:23,805 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 11:49:23,805 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 11:49:23,806 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 11:49:23,806 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2023-12-01 11:49:23,806 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2023-12-01 11:49:23,818 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 104.103.158.73
2023-12-01 11:49:23,828 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2023-12-01 11:49:23,830 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: S_I: MTA0LjEwMy4xNTguNzM=
2023-12-01 11:49:23,830 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjY0
2023-12-01 11:49:23,830 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2023-12-01 11:49:23,830 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2023-12-01 11:49:23,875 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Update status: full
2023-12-01 11:49:23,875 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-01 11:49:23,876 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-01 11:49:23,902 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 11:49:23,903 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 11:49:23,903 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 11:49:23,968 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Update status: full
2023-12-01 11:49:23,968 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Searching the database for installed apps to update
2023-12-01 11:49:23,970 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Currently installed version for app 73e72ada57b7480280f7a6f4a289729f is 2.0.17954(20231130181907)
2023-12-01 11:49:23,970 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Try to fetch full update manifest file.
2023-12-01 11:49:23,970 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-01 11:49:23,970 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-01 11:49:23,996 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 11:49:23,996 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 11:49:23,996 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 11:49:24,038 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Update status: full
2023-12-01 11:49:24,038 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: App(73e72ada57b7480280f7a6f4a289729f) is already installed, skip updating.
2023-12-01 11:49:24,038 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: No apps need to install/live update.
2023-12-01 11:49:24,966 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2023-12-01 11:49:24,966 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2023-12-01 11:49:24,967 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2023-12-01 11:49:24,967 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 11:49:24,967 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000020AF76656D0> #
2023-12-01 11:49:24,967 - MainProcess(18036) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-01 16:34:29,546 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\alexb\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2023-12-01 16:34:29,548 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2023-12-01 16:34:29,548 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 16:34:29,548 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x00000210C3FB54D0> #
2023-12-01 16:34:29,548 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-01 16:34:29,548 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\resources\buildinfo.json
2023-12-01 16:34:29,549 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2023-12-01 16:34:29,549 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20231122000000
2023-12-01 16:34:29,550 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_GB
2023-12-01 16:34:29,552 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\resources
2023-12-01 16:34:29,553 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer - INFO :: New logging level: 20
2023-12-01 16:34:29,554 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: Start to run process: Update
2023-12-01 16:34:29,765 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2023-12-01 16:34:30,168 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: Skipping pre-checks. Found environment variable SKIP_PRECHECK OR Admin install.
2023-12-01 16:34:30,172 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2023-12-01 16:34:30,172 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2023-12-01 16:34:30,173 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2023-12-01 16:34:30,258 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2023-12-01 16:34:30,258 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-01 16:34:30,259 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-01 16:34:30,301 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 16:34:30,301 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 16:34:30,302 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 16:34:30,302 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2023-12-01 16:34:30,302 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2023-12-01 16:34:30,316 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 104.103.158.73
2023-12-01 16:34:30,325 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2023-12-01 16:34:30,342 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: S_I: MTA0LjEwMy4xNTguNzM=
2023-12-01 16:34:30,343 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjY0
2023-12-01 16:34:30,343 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2023-12-01 16:34:30,343 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2023-12-01 16:34:30,393 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Update status: full
2023-12-01 16:34:30,394 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-01 16:34:30,394 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-01 16:34:30,421 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 16:34:30,422 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 16:34:30,422 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 16:34:30,468 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Update status: full
2023-12-01 16:34:30,469 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Searching the database for installed apps to update
2023-12-01 16:34:30,470 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Currently installed version for app 73e72ada57b7480280f7a6f4a289729f is 2.0.17954(20231130181907)
2023-12-01 16:34:30,470 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Try to fetch full update manifest file.
2023-12-01 16:34:30,470 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-01 16:34:30,470 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-01 16:34:30,498 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-01 16:34:30,499 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-01 16:34:30,499 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-01 16:34:30,564 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: Update status: full
2023-12-01 16:34:30,564 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: App(73e72ada57b7480280f7a6f4a289729f) is already installed, skip updating.
2023-12-01 16:34:30,564 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.process.update_process - INFO :: No apps need to install/live update.
2023-12-01 16:34:31,547 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2023-12-01 16:34:31,547 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2023-12-01 16:34:31,548 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2023-12-01 16:34:31,548 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 16:34:31,548 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x00000210C3FB54D0> #
2023-12-01 16:34:31,548 - MainProcess(25900) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-01 17:08:01,846 - MainProcess(26544) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\alexb\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2023-12-01 17:08:01,847 - MainProcess(26544) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2023-12-01 17:08:01,847 - MainProcess(26544) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 17:08:01,847 - MainProcess(26544) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000026EC9B72790> #
2023-12-01 17:08:01,847 - MainProcess(26544) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-01 17:08:01,847 - MainProcess(26544) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\streamer\20231122000000\resources\buildinfo.json
2023-12-01 17:08:01,851 - MainProcess(26544) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2023-12-01 17:08:01,851 - MainProcess(26544) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20231122000000
2023-12-01 17:08:01,851 - MainProcess(26544) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_GB
2023-12-01 17:08:01,856 - MainProcess(26544) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\streamer\20231122000000\resources
2023-12-01 17:08:01,857 - MainProcess(26544) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\streamer\20231122000000\certs.pem
2023-12-01 17:08:01,857 - MainProcess(26544) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2023-12-01 17:08:01,858 - MainProcess(26544) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2023-12-01 17:08:01,858 - MainProcess(26544) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2023-12-01 17:08:01,858 - MainProcess(26544) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function uninstall_process at 0x0000026ECA4F7BA0>, operation=<function multiple_operate at 0x0000026EC9BDFC40>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection=None, update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=True, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=True, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2023-12-01 17:08:01,858 - MainProcess(26544) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2023-12-01 17:08:01,858 - MainProcess(26544) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2023-12-01 17:08:01,858 - MainProcess(26544) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2023-12-01 17:08:01,859 - MainProcess(26544) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2023-12-01 17:08:01,859 - MainProcess(26544) - MessageThread - adsk.dls.streamer.ui.headless - INFO :: Begin sending message in headless mode.
2023-12-01 17:08:01,860 - MainProcess(26544) - MainThread - adsk.dls.streamer.process.process - INFO :: Start to run process: Cleanup
2023-12-01 17:08:01,946 - MainProcess(26544) - MainThread - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2023-12-01 17:08:02,349 - MainProcess(26544) - MainThread - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2023-12-01 17:08:02,349 - MainProcess(26544) - MainThread - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2023-12-01 17:08:02,350 - MainProcess(26544) - MainThread - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2023-12-01 17:08:02,350 - MainProcess(26544) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2023-12-01 17:08:02,350 - MainProcess(26544) - MainThread - adsk.dls.streamer.process.process - INFO :: The session id is fc4ca2e9-eba2-4387-9598-e18343fe4127
2023-12-01 17:08:02,351 - MainProcess(26544) - MainThread - adsk.dls.streamer.process.process - INFO :: Configure app begin Cleanup
2023-12-01 17:08:02,351 - MainProcess(26544) - MainThread - adsk.dls.streamer.process.uninstall_process - INFO :: Cleaning up old-version apps, ignoring any apps except for packages belonging to an in-progress app
2023-12-01 17:08:02,351 - MainProcess(26544) - MainThread - adsk.dls.streamer.process.uninstall_process - INFO :: Check app: 73e72ada57b7480280f7a6f4a289729f
2023-12-01 17:08:02,372 - MainProcess(26544) - MainThread - adsk.dls.streamer.process.process - INFO :: Configure app complete Cleanup
2023-12-01 17:08:02,372 - MainProcess(26544) - MainThread - adsk.dls.streamer.process.process - INFO :: Process Complete in 0.021940947 seconds
2023-12-01 17:08:03,939 - MainProcess(26544) - MainThread - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2023-12-01 17:08:03,952 - MainProcess(26544) - MainThread - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2023-12-01 17:08:03,952 - MainProcess(26544) - MainThread - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2023-12-01 17:08:03,952 - MainProcess(26544) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2023-12-01 17:08:03,952 - MainProcess(26544) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000026EC9B72790> #
2023-12-01 17:08:03,952 - MainProcess(26544) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-21 09:23:47,784 - MainProcess(22200) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\alexb\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2023-12-21 09:23:47,784 - MainProcess(22200) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2023-12-21 09:23:47,784 - MainProcess(22200) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2023-12-21 09:23:47,784 - MainProcess(22200) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000022093838A90> #
2023-12-21 09:23:47,785 - MainProcess(22200) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2023-12-21 09:23:47,785 - MainProcess(22200) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-21 09:23:47,785 - MainProcess(22200) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\alexb\AppData\Local\Temp\7zS5852.tmp\resources\buildinfo.json
2023-12-21 09:23:47,785 - MainProcess(22200) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2023-12-21 09:23:47,785 - MainProcess(22200) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20231122000000
2023-12-21 09:23:47,785 - MainProcess(22200) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_GB
2023-12-21 09:23:47,786 - MainProcess(22200) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\alexb\AppData\Local\Temp\7zS5852.tmp\resources
2023-12-21 09:23:47,786 - MainProcess(22200) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\alexb\AppData\Local\Temp\7zS5852.tmp\certs.pem
2023-12-21 09:23:47,786 - MainProcess(22200) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2023-12-21 09:23:47,787 - MainProcess(22200) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2023-12-21 09:23:47,787 - MainProcess(22200) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2023-12-21 09:23:47,787 - MainProcess(22200) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x000002209381D080>, operation=<function multiple_operate at 0x0000022092F054E0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2023-12-21 09:23:47,788 - MainProcess(22200) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2023-12-21 09:23:47,788 - MainProcess(22200) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2023-12-21 09:23:47,788 - MainProcess(22200) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2023-12-21 09:23:47,788 - MainProcess(22200) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2023-12-21 09:23:48,151 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2023-12-21 09:23:48,225 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2023-12-21 09:23:48,668 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2023-12-21 09:23:48,669 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2023-12-21 09:23:48,669 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2023-12-21 09:23:48,669 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2023-12-21 09:23:48,669 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2023-12-21 09:23:48,669 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2023-12-21 09:23:48,669 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\alexb\AppData\Local\Autodesk\check_perm
2023-12-21 09:23:48,670 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\alexb\AppData\Local\Autodesk\check_perm created successfully
2023-12-21 09:23:48,670 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\alexb\AppData\Local\Autodesk\check_perm
2023-12-21 09:23:48,670 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\alexb\AppData\Local\Autodesk\check_perm removed successfully
2023-12-21 09:23:48,670 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\alexb\AppData\Local\Autodesk
2023-12-21 09:23:48,670 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2023-12-21 09:23:48,670 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2023-12-21 09:23:48,670 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2023-12-21 09:23:48,694 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:23:48,695 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:23:48,695 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:23:48,695 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2023-12-21 09:23:48,695 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2023-12-21 09:23:48,697 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 104.82.197.165
2023-12-21 09:23:48,706 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2023-12-21 09:23:48,709 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0LjgyLjE5Ny4xNjU=
2023-12-21 09:23:48,709 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjE0OQ==
2023-12-21 09:23:48,709 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2023-12-21 09:23:48,709 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2023-12-21 09:23:48,775 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x000002209385F490>
2023-12-21 09:23:48,775 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2023-12-21 09:23:48,806 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2023-12-21 09:23:48,806 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.82.197.165
2023-12-21 09:23:48,806 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-21 09:23:48,806 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-21 09:23:48,826 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:23:48,826 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:23:48,826 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:23:48,894 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2023-12-21 09:23:48,894 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2023-12-21 09:23:48,894 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2023-12-21 09:23:48,894 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2023-12-21 09:23:48,913 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:23:48,913 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:23:48,913 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:23:48,969 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x00000220938770D0>
2023-12-21 09:23:48,970 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2023-12-21 09:23:48,979 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2023-12-21 09:23:48,980 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.82.197.165
2023-12-21 09:23:48,998 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:23:48,998 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:23:48,998 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:23:49,049 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000022093876A10>
2023-12-21 09:23:49,049 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2023-12-21 09:23:49,049 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2023-12-21 09:23:49,049 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2023-12-21 09:23:49,069 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:23:49,069 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:23:49,069 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:23:49,118 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000022093876E50>
2023-12-21 09:23:49,118 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2023-12-21 09:23:49,150 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2023-12-21 09:23:49,150 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.82.197.165
2023-12-21 09:23:49,150 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-21 09:23:49,150 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-21 09:23:49,169 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:23:49,169 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:23:49,169 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:23:49,239 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Will perform incremental deploy for app 73e72ada57b7480280f7a6f4a289729f
2023-12-21 09:23:49,239 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2023-12-21 09:23:49,239 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2023-12-21 09:23:49,240 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2023-12-21 09:23:49,240 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-21 09:23:49,240 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-21 09:23:49,258 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:23:49,258 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:23:49,258 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:23:49,347 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Will perform incremental deploy for app 73e72ada57b7480280f7a6f4a289729f
2023-12-21 09:23:49,347 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is 9cec9e93-421c-4369-bab6-95d92125cb77
2023-12-21 09:23:49,357 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.17954 for app 73e72ada57b7480280f7a6f4a289729f
2023-12-21 09:23:49,386 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2023-12-21 09:23:49,388 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0LjgyLjE5Ny4xNjU=
2023-12-21 09:23:49,388 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjE0OQ==
2023-12-21 09:23:49,459 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOiAgYnRodWIuaG9tZQ0sIEFkZHJlc3M6ICBmZTgwOjplNjc1OmRjZmY6ZmU4MzpjNTViDQ==
2023-12-21 09:23:49,460 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2023-12-21 09:23:49,460 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "R:\src\adsk\dls\streamer\process\process.py", line 1186, in execute
File "R:\src\adsk\dls\streamer\process\deploy_process.py", line 95, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 1116, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 884, in _config_app
adsk.dls.streamer.exceptions.VersionExists: No need to update. 2.0.17954 installed
2023-12-21 09:23:55,153 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2023-12-21 09:23:55,690 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2023-12-21 09:23:55,694 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Launch
2023-12-21 09:23:56,084 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2023-12-21 09:23:56,084 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2023-12-21 09:23:56,084 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2023-12-21 09:23:56,084 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-21 09:23:56,084 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-21 09:23:56,102 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:23:56,102 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:23:56,102 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:23:56,166 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is f4524b13-faa0-4a7e-9f30-e8e6d0638605
2023-12-21 09:23:56,166 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Launch to 2.0.17954 for app 73e72ada57b7480280f7a6f4a289729f
2023-12-21 09:23:56,174 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Found launch executable: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\Fusion360.exe
2023-12-21 09:23:56,174 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.launch_process - INFO :: Launch executable is \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\Fusion360.exe
2023-12-21 09:23:56,174 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.windows.platform - INFO :: Attempting to launch: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\Fusion360.exe
2023-12-21 09:23:56,206 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2023-12-21 09:23:56,208 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0LjgyLjE5Ny4xNjU=
2023-12-21 09:23:56,208 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjE0OQ==
2023-12-21 09:23:56,273 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOiAgYnRodWIuaG9tZQ0sIEFkZHJlc3M6ICBmZTgwOjplNjc1OmRjZmY6ZmU4MzpjNTViDQ==
2023-12-21 09:23:56,273 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2023-12-21 09:23:56,274 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
File "R:\src\adsk\dls\streamer\ui\jsbridge.py", line 205, in reporterror
During handling of the above exception, another exception occurred:
File "R:\src\adsk\dls\streamer\process\launch_process.py", line 80, in _config_app
File "R:\src\adsk\dls\streamer\windows\platform.py", line 456, in launchpath
File "E:\Jenkins\3P\PYTHON\3.11.1\WIN64_1\Lib\subprocess.py", line 1024, in __init__
File "E:\Jenkins\3P\PYTHON\3.11.1\WIN64_1\Lib\subprocess.py", line 1493, in _execute_child
FileNotFoundError: [WinError 2] The system cannot find the file specified
2023-12-21 09:24:23,642 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2023-12-21 09:24:23,659 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.process.process - WARNING :: Exception in Launch [WinError 2] The system cannot find the file specified
2023-12-21 09:24:25,010 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2023-12-21 09:24:25,014 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2023-12-21 09:24:25,014 - MainProcess(22200) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # #
2023-12-21 09:30:41,433 - MainProcess(13988) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\alexb\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2023-12-21 09:30:41,434 - MainProcess(13988) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2023-12-21 09:30:41,434 - MainProcess(13988) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2023-12-21 09:30:41,434 - MainProcess(13988) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000019EAC5DC210> #
2023-12-21 09:30:41,434 - MainProcess(13988) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-21 09:30:41,434 - MainProcess(13988) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\alexb\AppData\Local\Temp\7zSA85A.tmp\resources\buildinfo.json
2023-12-21 09:30:41,434 - MainProcess(13988) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2023-12-21 09:30:41,434 - MainProcess(13988) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20231122000000
2023-12-21 09:30:41,434 - MainProcess(13988) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_GB
2023-12-21 09:30:41,435 - MainProcess(13988) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\alexb\AppData\Local\Temp\7zSA85A.tmp\resources
2023-12-21 09:30:41,436 - MainProcess(13988) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\alexb\AppData\Local\Temp\7zSA85A.tmp\certs.pem
2023-12-21 09:30:41,436 - MainProcess(13988) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2023-12-21 09:30:41,437 - MainProcess(13988) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2023-12-21 09:30:41,437 - MainProcess(13988) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2023-12-21 09:30:41,437 - MainProcess(13988) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x0000019EAC5BCFE0>, operation=<function multiple_operate at 0x0000019EABCA5440>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2023-12-21 09:30:41,437 - MainProcess(13988) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2023-12-21 09:30:41,437 - MainProcess(13988) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2023-12-21 09:30:41,437 - MainProcess(13988) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2023-12-21 09:30:41,437 - MainProcess(13988) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2023-12-21 09:30:41,662 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2023-12-21 09:30:41,718 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2023-12-21 09:30:42,122 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2023-12-21 09:30:42,122 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2023-12-21 09:30:42,122 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2023-12-21 09:30:42,123 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2023-12-21 09:30:42,123 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2023-12-21 09:30:42,123 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2023-12-21 09:30:42,123 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\alexb\AppData\Local\Autodesk\check_perm
2023-12-21 09:30:42,123 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\alexb\AppData\Local\Autodesk\check_perm created successfully
2023-12-21 09:30:42,123 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\alexb\AppData\Local\Autodesk\check_perm
2023-12-21 09:30:42,124 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\alexb\AppData\Local\Autodesk\check_perm removed successfully
2023-12-21 09:30:42,124 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\alexb\AppData\Local\Autodesk
2023-12-21 09:30:42,124 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2023-12-21 09:30:42,124 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2023-12-21 09:30:42,124 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2023-12-21 09:30:42,147 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:30:42,148 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:30:42,148 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:30:42,148 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2023-12-21 09:30:42,148 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2023-12-21 09:30:42,170 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 104.82.197.165
2023-12-21 09:30:42,197 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2023-12-21 09:30:42,199 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0LjgyLjE5Ny4xNjU=
2023-12-21 09:30:42,199 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjE0OQ==
2023-12-21 09:30:42,199 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2023-12-21 09:30:42,200 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2023-12-21 09:30:42,250 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000019EAC5DFE50>
2023-12-21 09:30:42,250 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2023-12-21 09:30:42,260 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2023-12-21 09:30:42,260 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.82.197.165
2023-12-21 09:30:42,260 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-21 09:30:42,261 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-21 09:30:42,279 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:30:42,279 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:30:42,279 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:30:42,360 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2023-12-21 09:30:42,360 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2023-12-21 09:30:42,360 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2023-12-21 09:30:42,361 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2023-12-21 09:30:42,379 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:30:42,379 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:30:42,379 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:30:42,482 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000019EAC60EC10>
2023-12-21 09:30:42,483 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2023-12-21 09:30:42,493 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2023-12-21 09:30:42,493 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.82.197.165
2023-12-21 09:30:42,512 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:30:42,512 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:30:42,512 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:30:42,566 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000019EAC60E550>
2023-12-21 09:30:42,566 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2023-12-21 09:30:42,566 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2023-12-21 09:30:42,566 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2023-12-21 09:30:42,586 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:30:42,586 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:30:42,586 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:30:42,642 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000019EAC60E990>
2023-12-21 09:30:42,643 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2023-12-21 09:30:42,663 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2023-12-21 09:30:42,664 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.82.197.165
2023-12-21 09:30:42,664 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-21 09:30:42,664 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-21 09:30:42,683 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:30:42,683 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:30:42,683 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:30:42,732 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Will perform incremental deploy for app 73e72ada57b7480280f7a6f4a289729f
2023-12-21 09:30:42,732 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2023-12-21 09:30:42,732 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2023-12-21 09:30:42,732 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2023-12-21 09:30:42,732 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-21 09:30:42,732 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-21 09:30:42,751 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:30:42,751 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:30:42,751 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:30:42,822 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Will perform incremental deploy for app 73e72ada57b7480280f7a6f4a289729f
2023-12-21 09:30:42,822 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is 554d5c34-c2aa-4584-8c37-557e572e8869
2023-12-21 09:30:42,831 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.17954 for app 73e72ada57b7480280f7a6f4a289729f
2023-12-21 09:30:42,866 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2023-12-21 09:30:42,868 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0LjgyLjE5Ny4xNjU=
2023-12-21 09:30:42,868 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjE0OQ==
2023-12-21 09:30:42,934 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOiAgYnRodWIuaG9tZQ0sIEFkZHJlc3M6ICBmZTgwOjplNjc1OmRjZmY6ZmU4MzpjNTViDQ==
2023-12-21 09:30:42,935 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2023-12-21 09:30:42,935 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
2023-12-21 09:30:49,962 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2023-12-21 09:30:49,979 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.process.process - WARNING :: Exception in Deploy No need to update. 2.0.17954 installed
2023-12-21 09:30:51,385 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2023-12-21 09:30:51,390 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2023-12-21 09:30:51,390 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2023-12-21 09:30:51,390 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # #
2023-12-21 09:30:51,390 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000019EAC5DC210> #
2023-12-21 09:30:51,391 - MainProcess(13988) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-21 09:30:55,760 - MainProcess(15508) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\alexb\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2023-12-21 09:30:55,761 - MainProcess(15508) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2023-12-21 09:30:55,761 - MainProcess(15508) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2023-12-21 09:30:55,761 - MainProcess(15508) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x00000169D73185D0> #
2023-12-21 09:30:55,761 - MainProcess(15508) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2023-12-21 09:30:55,761 - MainProcess(15508) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\alexb\AppData\Local\Temp\7zSE042.tmp\resources\buildinfo.json
2023-12-21 09:30:55,761 - MainProcess(15508) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2023-12-21 09:30:55,761 - MainProcess(15508) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20231122000000
2023-12-21 09:30:55,761 - MainProcess(15508) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_GB
2023-12-21 09:30:55,762 - MainProcess(15508) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\alexb\AppData\Local\Temp\7zSE042.tmp\resources
2023-12-21 09:30:55,762 - MainProcess(15508) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\alexb\AppData\Local\Temp\7zSE042.tmp\certs.pem
2023-12-21 09:30:55,763 - MainProcess(15508) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2023-12-21 09:30:55,763 - MainProcess(15508) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2023-12-21 09:30:55,763 - MainProcess(15508) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2023-12-21 09:30:55,764 - MainProcess(15508) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x00000169D72FCFE0>, operation=<function multiple_operate at 0x00000169D69E5440>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2023-12-21 09:30:55,764 - MainProcess(15508) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2023-12-21 09:30:55,764 - MainProcess(15508) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2023-12-21 09:30:55,764 - MainProcess(15508) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2023-12-21 09:30:55,764 - MainProcess(15508) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2023-12-21 09:30:55,955 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2023-12-21 09:30:56,005 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2023-12-21 09:30:56,455 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2023-12-21 09:30:56,456 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2023-12-21 09:30:56,456 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2023-12-21 09:30:56,456 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2023-12-21 09:30:56,456 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2023-12-21 09:30:56,456 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2023-12-21 09:30:56,456 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\alexb\AppData\Local\Autodesk\check_perm
2023-12-21 09:30:56,457 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\alexb\AppData\Local\Autodesk\check_perm created successfully
2023-12-21 09:30:56,457 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\alexb\AppData\Local\Autodesk\check_perm
2023-12-21 09:30:56,457 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\alexb\AppData\Local\Autodesk\check_perm removed successfully
2023-12-21 09:30:56,457 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\alexb\AppData\Local\Autodesk
2023-12-21 09:30:56,457 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2023-12-21 09:30:56,457 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2023-12-21 09:30:56,457 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2023-12-21 09:30:56,481 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:30:56,481 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:30:56,481 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:30:56,481 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2023-12-21 09:30:56,481 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2023-12-21 09:30:56,482 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 104.82.197.165
2023-12-21 09:30:56,491 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2023-12-21 09:30:56,493 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0LjgyLjE5Ny4xNjU=
2023-12-21 09:30:56,493 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjE0OQ==
2023-12-21 09:30:56,494 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2023-12-21 09:30:56,494 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2023-12-21 09:30:56,547 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x00000169D731B590>
2023-12-21 09:30:56,547 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2023-12-21 09:30:56,578 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2023-12-21 09:30:56,578 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.82.197.165
2023-12-21 09:30:56,578 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-21 09:30:56,578 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-21 09:30:56,597 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:30:56,597 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:30:56,597 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:30:56,651 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2023-12-21 09:30:56,651 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2023-12-21 09:30:56,651 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2023-12-21 09:30:56,651 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2023-12-21 09:30:56,669 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:30:56,669 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:30:56,669 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:30:56,717 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x00000169D7356E10>
2023-12-21 09:30:56,717 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2023-12-21 09:30:56,751 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2023-12-21 09:30:56,751 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.82.197.165
2023-12-21 09:30:56,771 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:30:56,771 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:30:56,771 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:30:56,818 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x00000169D7356750>
2023-12-21 09:30:56,818 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2023-12-21 09:30:56,818 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2023-12-21 09:30:56,818 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2023-12-21 09:30:56,838 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:30:56,838 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:30:56,838 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:30:56,890 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x00000169D7356CD0>
2023-12-21 09:30:56,890 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2023-12-21 09:30:56,904 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2023-12-21 09:30:56,905 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.82.197.165
2023-12-21 09:30:56,905 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-21 09:30:56,905 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-21 09:30:56,924 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:30:56,924 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:30:56,924 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:30:57,007 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Will perform incremental deploy for app 73e72ada57b7480280f7a6f4a289729f
2023-12-21 09:30:57,007 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2023-12-21 09:30:57,007 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2023-12-21 09:30:57,007 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2023-12-21 09:30:57,007 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-21 09:30:57,007 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-21 09:30:57,026 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:30:57,027 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:30:57,027 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:30:57,109 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Will perform incremental deploy for app 73e72ada57b7480280f7a6f4a289729f
2023-12-21 09:30:57,109 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is d3ebe6c8-fd0a-4bef-bc50-ae78a92d444c
2023-12-21 09:30:57,118 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.17954 for app 73e72ada57b7480280f7a6f4a289729f
2023-12-21 09:30:57,141 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2023-12-21 09:30:57,143 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0LjgyLjE5Ny4xNjU=
2023-12-21 09:30:57,143 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjE0OQ==
2023-12-21 09:30:57,212 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOiAgYnRodWIuaG9tZQ0sIEFkZHJlc3M6ICBmZTgwOjplNjc1OmRjZmY6ZmU4MzpjNTViDQ==
2023-12-21 09:30:57,212 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2023-12-21 09:30:57,212 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
2023-12-21 09:30:58,590 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2023-12-21 09:30:59,074 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2023-12-21 09:30:59,079 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Launch
2023-12-21 09:30:59,516 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\alexb\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2023-12-21 09:30:59,517 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2023-12-21 09:30:59,517 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2023-12-21 09:30:59,517 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2023-12-21 09:30:59,517 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2023-12-21 09:30:59,535 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2023-12-21 09:30:59,535 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2023-12-21 09:30:59,535 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2023-12-21 09:30:59,604 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is 58003782-eae6-49d5-9abb-32f6acbc0383
2023-12-21 09:30:59,604 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Launch to 2.0.17954 for app 73e72ada57b7480280f7a6f4a289729f
2023-12-21 09:30:59,611 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Found launch executable: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\Fusion360.exe
2023-12-21 09:30:59,611 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.launch_process - INFO :: Launch executable is \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\Fusion360.exe
2023-12-21 09:30:59,611 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.windows.platform - INFO :: Attempting to launch: \\?\C:\Users\alexb\AppData\Local\Autodesk\webdeploy\production\b0c303e70bd97cfdc195adab65922cfeffcb363a\Fusion360.exe
2023-12-21 09:30:59,643 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2023-12-21 09:30:59,645 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0LjgyLjE5Ny4xNjU=
2023-12-21 09:30:59,645 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjE0OQ==
2023-12-21 09:30:59,710 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOiAgYnRodWIuaG9tZQ0sIEFkZHJlc3M6ICBmZTgwOjplNjc1OmRjZmY6ZmU4MzpjNTViDQ==
2023-12-21 09:30:59,711 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2023-12-21 09:30:59,711 - MainProcess(15508) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
