Cant install fusion360, erron22
mikkel-jensen-danmark
Community Visitor
Community Visitor
OSError: [Errno 22] Invalid argument
what to do ? i have tried everything, uninstall, update windows, delete whole program and everything
please help !! i have upload the error log
RajkumarIlanchelian
@mikkel-jensen-danmark This should help:
1. Make sure that Fusion installer is not running in task manager
2. Go to %localappdata%\Autodesk\ then DELETE the following folders – Webdeploy, Web Services, Identity services, Autodesk Fusion 360 ((IF you do not have any other Autodesk products installed, delete the Full Autodesk folder)
3. Delete the shortcut that is used to launch Fusion
4. Restart your machine
5. Do not use the same Fusion installer. Can you please download the installer again
6. Now install again
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
