Message 1 of 10
05:06 AM
Hi there,
I am trying to extrude a sketch from an imported DXF file. It should be very simple but for some reason I cannot extrude the sketch. Fusion 360 does not allow me to select the shape when using the extrude tool. Any ideas what I am missing?
I cant attach the DXF to the forum, it says:
Correct the highlighted errors and try again.
The attachment's dxf 2 extrude.dxf content type (application/x-dxf) does not match its file extension and has been removed.
I have re-exported the DXF out of Fusion 360 from the sketch so the DXF file itself should be okay. I can't understand what the problem is.
Thanks in advanced for any insight you can offer..
